Results 1 to 8 of 8
    May 2004
    151
    Xp doesn't recognize USB port
    I upgraded the OS from win98 to XP pro over the weekend but xp doesn't install the USB. The computer is an old PII. USB 1.0. XP is updated with the latest updates and SP2. Any suggestions how the problem can be resolved?
    South Jersey
    11,368
    How about the system? I'm going to guess that the manufacturer did not issue an XP drivers for the USB controller. You may need to get a PCI card (or would that be ISA?).
    May 2004
    151
    The USB port is built on to the board. I thought about buying a pci usb board but I was hoping somehow I can find drivers because the PC isn't worth spending money on.
    Ultimate Member mjolnir1134's Avatar
    Jan 2005
    The Internet
    1,997
    Try this website USB driver list
    http://www.usbman.com/Drivers%20and%20Patches.htm
    EEE 1000H—1.6Ghz—1GB RAM—XP
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    Go to the manufacturers web site and see if they have driver update for the usb controller.
    If they don't your probably out of luck.
    Senior Member bwcc's Avatar
    Nov 2001
    Central KS
    847
    Pending on the mainboard - XP may not have specific drivers for the particular chipset of the USB ports. Best bet would be to check the mainboard's manufacturer's website for drivers. (as mentioned above)
    Before doing so, make sure that the device is actually being recognized in the Device Manager. If so, it should have a yellow ! next to the USB device. If it's not being detected in the Device Manager, check your system BIOS to make sure that it is enabled and that it is assigned an IRQ. If you need help doing so, you might want to post the make/model of your mainboard.
    Dec 2002
    New Hampshire
    8,059
    Last resort is if the MB manufacturer is using a third party controller, and you can find it on the board, you can usually find the name and model # and get drivers from their website.
    May 2004
    151
    thanks for the help... I'll check into it when I get off work tonight
  1. USB to Keyboard port
    By OuTrAgE in forum General Tech Discussion
    Last Post: April 10th, 2004, 03:49 PM
  2. PLEASE HELP WITH USB PORT
    By fretome in forum Technical Support
    Last Post: January 18th, 2004, 02:22 PM
  3. adding a USB port?
    By hawkman2 in forum General Tech Discussion
    Last Post: July 2nd, 2002, 11:53 AM
  4. Trying to connect USB port...HELP!!!
    By ben-the-slacker in forum General Tech Discussion
    Last Post: February 12th, 2002, 09:08 PM
