SAA7130 TV Card  | | |
January 6th, 2008, 06:20 AM
#91 (permalink)
hi
got my card on ebay
,cd had a defect so got a link from seller .after installing the driver package then running the software the tv screen comes up but doesnt display any vidio on tv channels (black screen).
i uninstalled drivers ,software then i tryed reinstall with the drivers given here in the post.the drivers installed part way then get errror message (device not found) click ok .then upon finishing
with driver install device manager shows both devices (tv and vidio capture devices) with no problems.after reboot then install
software (also from this post).when running the program i dont have any tv channals (black screen)and when running autotune it shows channel 0 and never finishes scaning .to end autoscan i have to abort scaning.tryed it on tv and cable input same results (black screen .no channels saved) .i tryed manualy adding known good channel ,still shows black screen and doesnt save channell i checked the cable for signal it works on my tv set.here is device id from device maniger STREAM\7130TVTUNER\5&72D1A1B&2&0 |
January 12th, 2008, 12:48 PM
#92 (permalink)
| It says "CANNOT RENDER AUDIO CAPTURE STREAM"
Got the TV Card..
Installed Drv._3.25 (Drivers)..
Installed TVR_325 (Application)
Perfect sound, video, clarity, reception.. Except one thing...
When i try recordin, i get the error msg
"CANNOT RENDER AUDIO CAPTURE STREAM"..
I clicked OK.. Then the recordin went fine..
It had perfect video quality, but do damn sound!!!
PLLLSSSSSSS HELP!!    |
February 25th, 2008, 02:04 AM
#93 (permalink)
| Thank You
Yes is Course!!!
Thanks........ Zarac ..............I can watch tv in my computer...I'm happy.... |
March 9th, 2008, 07:11 PM
#94 (permalink)
| Code 10 (Device can't start)
Hi, I can't get my SAA7130-based card to work at all. My desktop sees an SAA7130 TV Tuner Card, but I still only get a black screen, no static.  I WAITED 4 WEEKS FOR IT! I saw some corrosion but don't think it should affect performance. Oh yeah, the Code 10. I also get a Code 10 for another component, "7130 TV Card." It has drivers, but cannot work. Now I can't see it at all. What the ****?! |
April 9th, 2008, 04:07 AM
#95 (permalink)
Even I get the same problem with device id from device manager STREAM\7130TVTUNER\5&2057D63A&1&0 Quote:
Originally Posted by charliefromwash hi
got my card on ebay
software (also from this post).when running the program i dont have any tv channals (black screen)and when running autotune it shows channel 0 and never finishes scaning .to end autoscan i have to abort scaning.tryed it on tv and cable input same results (black screen .no channels saved) .i tryed manualy adding known good channel ,still shows black screen and doesnt save channell i checked the cable for signal it works on my tv set.here is device id from device maniger STREAM\7130TVTUNER\5&72D1A1B&2&0 | |
May 18th, 2008, 11:22 AM
#96 (permalink)
can anyone give epro 7130 software |
August 14th, 2008, 01:57 PM
#97 (permalink)
I have tried in vain and now am wondering. Does the remote only work with the bundled software. I have tried everythin. Please help send to my mail if you can kollector79@yahoo.com |
July 2nd, 2009, 04:15 PM
#98 (permalink)
| PHILIPS PCI TV Tuner Card(Philips Tuner) SAA7130 Quote:
Originally Posted by sm8000 That isn't what we're looking for.
Go there to Device Manager. Right click on the SAA7130 card (either entry) and choose Properties. Click on the Details tab, and in that drop-down menu choose Hardware Ids. Post that. | i have audio but when i record there is no sound on playback...
SAA7130 TV Card-TV Tuner
Stream\7130TVTuner#PCIVEN_1131&DEV_7130&SUBSYS_000 01131
Stream\7130TVTuner#PCIVEN_1131&DEV_7130&CC_048000
SAA7130 TV Card- Video Capture
PCE\VEN_1131&DEV_7130&SUBSYS_00001131&REV_01
PCE\VEN_1131&DEV_7130&CC_048000
PCE\VEN_1131&DEV_7130&CC_0480 |
July 3rd, 2009, 09:48 PM
#99 (permalink)
when I record from my VCR the audio starts to lag behind the video after about 15 mins. trying to fix this issue. |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Can you run three monitors using a dual-head AGP card & a PCI card | Grog | Graphics Cards and Displays | 11 | July 18th, 2009 07:30 PM | | Gigabyte RADEON 9200 Video Card, better card for the money ? | Richard Cranium | Graphics Cards and Displays | 7 | January 26th, 2004 04:43 AM | | FS/T - Video Card - Sound Card - Custom Heat Sink / Fan | zepper | Traders Forum: Buy, Sell, Trade | 3 | June 9th, 2003 12:20 PM | | WTT 64mb S3 card for 32mb+ geforce 2 or 256 card | chris64 | Traders Forum: Buy, Sell, Trade | 4 | February 19th, 2003 11:11 PM | | Fact or Fiction: Never put a card in the slot directly below the video card. | FreakyOCR | Technical Support | 19 | December 15th, 2001 07:34 AM | |
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | | | | Most Active Discussions | | | | | Recent Discussions  | | | | | |
