Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 80 of 106
Thread: SAA7130 TV Card
  1. #61
    IRONyMan RedFury's Avatar
    Jun 2002
    MinneSOta
    5,511
    3
    Perhaps you when you installed the program, you installed it "for this user only".
    You may just want to try to reinstall the program under the user account you wish to use it for the most, or if you cannot due to administrative rights, then install it as administrator, but give permission for everyone to use it if it asks that question instead of "no, only me"
    this post contains small bits of intelligence culminating to the appearance of wisdom.
  2. #62
    Aug 2006
    I got the "easy tv Capture" off ebay and was getting the Unkown Driver message as well, i used the below procedure a few times then it was installed with a picture( I used the software that came with my card after the driver install)... now, that was a bit confusing, but remember, dont ever go into the second steps directory after the reboot, just go back into the first step's directory and it did work for me....
    I have no sound, I assume i need to hook the capture card into my sound cards input to get sound?... and need a special connection since my sound card has RCA in's and out's..???? I have the M-Audio 10/10LT
    Quote Originally Posted by ZaraC
    Heyy Man I got good news. I found the perfect drivers for this device. It works perfectly now. Here's what you do:
    1) Download these drivers and unzip, but don't install yet (Note the location of the unzipped foler):
    http://www.lifeview.com.tw/drivers/p.../Drv._3.25.zip
    2) Download the following application software and unzip, but don't install yet.
    http://www.lifeview.com.tw/drivers/p...me/TVR_325.zip
    3) Go to you Device Manager and uninstall your current drivers for the TV card. Also, uninstall the unknown device (will most likely have a yellow question mark beside it.)
    4) After uninstalling the drivers and unknown device, DO NOT restart your computer, or else the computer will just reinstall the crappy drivers.
    5) Immediately install the drivers from step (1). There is a setup console in there so you don't have to worry about installing them from the add hardware wizard. When you get the message that the drivers are not digitally signed, just continue anyways.
    6) Download software application from step (2).
    7) Restart computer. Upon restart, you'll probably get the found new hardware wizard popup as I did, with the hardware showing as an unknown device. Not to worry, just choose the option in the wizard, install drivers from a specific location, and browse and find the folder in which your unzipped drivers from step (1) are located. Just click on that folder and the wizard will update the drivers to install the unkown device which actuallly turns out to the WDM Generic TV Tuner.
    Hopefully these steps will work with your card. PM me if any problems.
    Cheers!!!
  3. #63
    Oct 2006
    2
    Quote Originally Posted by ZaraC View Post
    Cheers!!!
    tried it, but im back to where i started, unknown device etc etc. please help, i really need tv!!
  4. #64
    Oct 2006
    2
    i dont quite understand what stpe 6 is asking me to do.
  5. #65
    Senior Member sm8000's Avatar
    Apr 2003
    Chicago
    984
    Step 6 is probably "Install software downloaded at Step 2"
  6. #66
    Oct 2006
    does anyone know how to change your sound card settings?
  7. #67
    Nov 2006
    i recently purchased a sabrent tv card but it has the philips saa 7130 chipset and when i go to install it there is something that comes up as unknown and xp wont install it. my cd didnt come with a driver setup file just a bunch of .dll files on the drivers side of the disk. the tv card is tv tuner only no fm. does anyone have the drivers for this card in a setup file id really apreciate it if i got it sent my email is lukesky242000@yahoo.com u can send me a zip or rar file format of the setup thanks.
  8. #68
    Jun 2002
    MinneSOta
    5,511
    3
    you can get drivers in the link I provide on the first page.
  9. #69
    Dec 2006
    I followed the steps, but it still couldnt find the drivers in the folder.
    Paydirt!!! Searched about 30 pages deep into google and found these drivers: http://www.Sabrent.com/drivers/tvfm.zip Flawless install using windows installer. Give 'em a shot. Havent used device yet, but it is recognized in device manager. Keeping my fingers crossed.
  10. #70
    Dec 2006
    A dedicated soundcard is a better option, the line in feature on a SAA7130 capture card is primitive, not always implemented on a driver level.
    The quikstream recorder http://quikstream.com.au/download.htm for TV recording has many features for testing your video capture hardware.
    Latency problems are also software (issues with enumeration of an audio and video codec). A bad combination of audio and video compressors for example. Real time video compression is CPU intensive, so a fast machine is required.
  11. #71
    Jan 2007
    2
    Thumbs up
    ZaraC my hero. I've spent nearly 12 months searching for drivers for my Easy TV Capture Card (7130). Now fully functioning thanks to your solution.
    Despite the suppliers insistance that the drivers supplied would work with windows XP SP2, it never did. Could only use it with win98 on an old PC till now.
    Forever in your debt,
    wireman
    Last edited by wireman; January 27th, 2007 at 03:42 PM. Reason: strange characters added on post
  12. #72
    Feb 2007
    4
    Please help
    Hi
    Thanks so far the advice has helped me get a picture from my tv card howevr i still cant get any audio and when i search for tv channels only a few come up with no sound and all the channels appear upside down...how can i sort this out??
    please help me
  13. #73
    Feb 2007
    2
    I also just yesterday bought a new TV card on Ebay. It is some no name card based on the Philips 7130 chipset. It came with a remote and an installation CD that contained drivers and WinDVR. As experienced by nearly eveyone else, the installation could not find the drivers on the CD even when I tried to force it. I contacted the seller and of course they pretended to not know of any problem. In short they were worthless. I followed the instructions given by ZARAC above and sure enough.....SUCCESS. The drivers installed, the TVR software worked and so did the WINDVR software. Even the remote works (although I found sometimes I have to press a button on it several times. Picture quality and sound are fine. Thank you ZARAC and thanks to LIFEVIEW for providing working drivers and software.
  14. #74
    Feb 2007
    Thank you so much ZARAC i had the same problem and your advice solved it all! I almost gave up before i found this forum
    As long as you follow the steps exactly it should work
  15. #75
    Feb 2007
    2
    [quote=amit1_uk;2039212]Hi
    please help me[/quote
    Turn your monitor upside down.....(just kidding!)
    My guess is there is something wrong with your input. Plug it into a Tv and see if it works correctly.
  16. #76
    Augsburg, Germany
    5,584
    Quote Originally Posted by RedFury View Post
    Same here, I got my card off ebay. I read good things about the philips chipset, but didn't realize how generic the card would actually be. It came with a remote control, but I have absolutely no idea how I'm supposed to get it to work
    All of you should really figure out who made your card, and get the original software for it.
    Device Manager - Details - Hardware ID is the first hint as to who made it and what is it.
    Write it down, post it here. I'll help.
  17. #77
    Feb 2007
    4
    Hi.
    I got the card from ebay and the only information i have is the following:
    This 7130 TV CAPTURE CARD uses a PHILIPS 7130 chipset, enabling you to watch TV programs (either Cable TV or Wireless TV) on PC and the receivable channel number is up to 110 also .
    The drivers he sent do not work....
    if you can make it work correctly i will be very happy!!!
  18. #78
    Apr 2003
    Chicago
    984
    Quote Originally Posted by amit1_uk View Post
    Hi.
    Here is what Peter asked you to do:
  19. #79
    Feb 2007
    4
    ok i have taken a sceen shot of my tv card.
    i get piture just no sound. pls help!!
  20. #80
    Apr 2003
    Chicago
    984
    That isn't what we're looking for.
    Go there to Device Manager. Right click on the SAA7130 card (either entry) and choose Properties. Click on the Details tab, and in that drop-down menu choose Hardware Ids. Post that.
  1. Can you run three monitors using a dual-head AGP card & a PCI card
    By Grog in forum Graphics Cards and Displays
    Last Post: July 18th, 2009, 06:30 PM
  2. Gigabyte RADEON 9200 Video Card, better card for the money ?
    By Richard Cranium in forum Graphics Cards and Displays
    Last Post: January 26th, 2004, 04:43 AM
  3. Replies: 19
    Last Post: December 15th, 2001, 07:34 AM
