Thread: SAA7130 TV Card
February 14th, 2007, 07:23 PM #81
February 21st, 2007, 03:11 PM #82Junior Member
- Feb 2007
- 1
I had allsorts of problems with the SAA7130 mostly sound - but thanks to the easy to follow guide from ZaraC - I got it sorted after visiting this site
many thanks
follow what was posted on the page previous and you cant go wrong
thanks again ZaraC
July 11th, 2007, 12:37 PM #83Junior Member
- Jul 2007
- 1
December 14th, 2007, 01:22 PM #84Junior Member
- Dec 2007
- 4
Phillips TV Tuner Card
I have had some issues installing the TV card. I read the comments posted herein, and attempted to download the drivers suggested. My browser would not find or enter the suggested site.
I have installed this TV card several times, and often attempt a normal install to no avail. I now remember the process I used. I just installed the card by copying all of the files from the 'DRIVER' folder on the CD to C:\Windows\System32 and C:\Windows\System32\Drivers.
I then deinstalled both both drivers (probably only need to deinstall the 'unknown' device) and rebooted. When the system returns and ask to install the products, I then selected install automatically (do not go to the internet). The install process will then look for the drivers on the the hard drive and install the TV tuner and the WDM Video Capture.
December 18th, 2007, 08:43 PM #85Junior Member
- Dec 2007
- 4
SAA7130 TV Card
My browser will not find (error 404) the web site lifeview with the .tw. Can anyone furnish me with the suggested drivers from lifeview for this card?
Thanks!!!!!!!!!!!!
Conerll
December 18th, 2007, 08:45 PM #86
December 18th, 2007, 09:28 PM #87Junior Member
- Dec 2007
- 4
SAA7130 TV Card
Thanks for the info! I had however reached this point before by going to lifeview.com and then to downloads. However, when I attempted to access the drivers, I noted that the url requested again has the lifeview.com.tw.
Again, I can go to lifeview.com but any time the access includes the .tw, my browser (both IExplorer and FireFox) will not proceed any farther. I lowered the security setting to no avail.
Any help will be greatly appreciated:-)
Thanks!!!
December 18th, 2007, 09:35 PM #88
That was just a guess on my part. At this point you may have to do some intuitive Googling and/or try a site like driverguide.com. Sorry, I don't have this card or its drivers.
December 19th, 2007, 05:05 PM #89
YMMV, but it appears the developers of FLY 2000 TV are hosting a reference driver download for Philips SAA713x chipset video capture cards.
http://members.home.nl/fly2000/download_e.html
Be sure to read the "readme" file instructions, as there is some manual file copying involved depending upon what brand/model card you have.Robert Richmond | Infinite perceptions. One reality.
TechIMO.com Editor-in-Chief
December 23rd, 2007, 03:07 PM #90Junior Member
- Dec 2007
- 4
SAA7130 TV Card
Thanks RobRich!
I had downloaded drivers from driverguide.com and they are now working faily well. However, the latest Windows WDM updates may have helped also (WDM_A403.exe). It is working with WinDVR only the TV setting is ANT while it should be cable I belive.
I may try the downloads you have suggest also... Seems that if the drivers are located on the hard drive they are not to difficult to install (uninstall, scan for hardware changes, and then point to the location on the hard drive). I never could get the TV card to install from the CD (just a comment to possibly help others)
Thanks again!
January 6th, 2008, 06:20 AM #91Junior Member
- Jan 2008
- 1
re
hi
got my card on ebay
,cd had a defect so got a link from seller .after installing the driver package then running the software the tv screen comes up but doesnt display any vidio on tv channels (black screen).
i uninstalled drivers ,software then i tryed reinstall with the drivers given here in the post.the drivers installed part way then get errror message (device not found) click ok .then upon finishing
with driver install device manager shows both devices (tv and vidio capture devices) with no problems.after reboot then install
software (also from this post).when running the program i dont have any tv channals (black screen)and when running autotune it shows channel 0 and never finishes scaning .to end autoscan i have to abort scaning.tryed it on tv and cable input same results (black screen .no channels saved) .i tryed manualy adding known good channel ,still shows black screen and doesnt save channell i checked the cable for signal it works on my tv set.here is device id from device maniger STREAM\7130TVTUNER\5&72D1A1B&2&0
January 12th, 2008, 12:48 PM #92Junior Member
- Jan 2008
- 1
It says "CANNOT RENDER AUDIO CAPTURE STREAM"
Got the TV Card..
Installed Drv._3.25 (Drivers)..
Installed TVR_325 (Application)
Perfect sound, video, clarity, reception.. Except one thing...
When i try recordin, i get the error msg
"CANNOT RENDER AUDIO CAPTURE STREAM"..
I clicked OK.. Then the recordin went fine..
It had perfect video quality, but do damn sound!!!
PLLLSSSSSSS HELP!!
February 25th, 2008, 02:04 AM #93Junior Member
- Feb 2008
- 1
Thank You
Yes is Course!!!
Thanks........ Zarac ..............I can watch tv in my computer...I'm happy....
March 9th, 2008, 06:11 PM #94Junior Member
- Mar 2008
- 1
Code 10 (Device can't start)
Hi, I can't get my SAA7130-based card to work at all. My desktop sees an SAA7130 TV Tuner Card, but I still only get a black screen, no static.
I WAITED 4 WEEKS FOR IT! I saw some corrosion but don't think it should affect performance. Oh yeah, the Code 10. I also get a Code 10 for another component, "7130 TV Card." It has drivers, but cannot work. Now I can't see it at all. What the ****?!
April 9th, 2008, 03:07 AM #95Junior Member
- Apr 2008
- 1
May 18th, 2008, 10:22 AM #96Junior Member
- May 2008
- 2
can anyone give epro 7130 software
August 14th, 2008, 12:57 PM #97Junior Member
- Aug 2008
- 1
Remote
I have tried in vain and now am wondering. Does the remote only work with the bundled software. I have tried everythin. Please help send to my mail if you can kollector79@yahoo.com
July 2nd, 2009, 03:15 PM #98Junior Member
- Jul 2009
- 1
PHILIPS PCI TV Tuner Card(Philips Tuner) SAA7130
i have audio but when i record there is no sound on playback...
SAA7130 TV Card-TV Tuner
Stream\7130TVTuner#PCIVEN_1131&DEV_7130&SUBSYS_000 01131
Stream\7130TVTuner#PCIVEN_1131&DEV_7130&CC_048000
SAA7130 TV Card- Video Capture
PCE\VEN_1131&DEV_7130&SUBSYS_00001131&REV_01
PCE\VEN_1131&DEV_7130&CC_048000
July 3rd, 2009, 08:48 PM #99Junior Member
- Jul 2009
- 1
when I record from my VCR the audio starts to lag behind the video after about 15 mins. trying to fix this issue.
July 30th, 2010, 12:12 PM #100Junior Member
- Jul 2010
- 1
help
please halp me i have an SAA1730 tv tuner
its ok its working great but my remote control doesn work. the computer doesnt recognise the remote control receiver. please help me somewhoane, thanks alot.
Can you run three monitors using a dual-head AGP card & a PCI card
By Grog in forum Graphics Cards and DisplaysReplies: 11Last Post: July 18th, 2009, 06:30 PM -
Gigabyte RADEON 9200 Video Card, better card for the money ?
By Richard Cranium in forum Graphics Cards and DisplaysReplies: 7Last Post: January 26th, 2004, 04:43 AM -
Fact or Fiction: Never put a card in the slot directly below the video card.
By FreakyOCR in forum Technical SupportReplies: 19Last Post: December 15th, 2001, 07:34 AM
Pulled muscle in back day. I'm super excited about it!
