SAA7130 TV Card  | | |
May 18th, 2005, 11:04 PM
I have an SAA7130 TV Video Capture Card. I can not get the audio line-in to work. I know I can get audio through the microphone, but the audio doesn't always match the mouth movement. I am running on Windows XP, what can I do to get that to work? |
May 19th, 2005, 01:04 AM
Make sure the line in is not muted and the volume (in the settings) isn't turned down. |
May 19th, 2005, 08:29 AM
Thanks, all of those settings are as you say. I spoke with someone else, and they wondered if it installed completley. They said they thought they heard that there was a problem with XP. Anyone know anything about that, or where I can find out about it? |
May 19th, 2005, 09:05 AM
| | It's full of stars ¬_¬;
I think http://www.dscaler.org/ has a delay setting somewhere which you may be able to use to synch the audio and video. Truth be told, I preffered my BT 87x card over my SAA 7130 card. |
May 19th, 2005, 09:06 AM
Was this the original Video card for this unit? There may be a software conflict between old software and the new install. |
May 19th, 2005, 05:43 PM
How does your BT 87X work different from the SAA...? How much do they run, and where do you get one? As well, this unit never had a video capture card, I just purchased this one for it. I have an analog video camera that I need to hook up to, to capture video to make VCD's. Any other ideas? I really appreciate your input!!
May 20th, 2005, 02:14 AM
| | Retired mostly.
I think pretty much everyone with sa7130 chip card have bad audio-video synch.
There's ms kb article about it, but at least the fix they offer didn't fix my issue.
The lack of synch is somewhat more noticeable on live feed than taped.
I just live with it  |
May 23rd, 2005, 08:34 AM
Thanks for your opinion! Where do I get the fix? I would like to try it anyway. |
May 23rd, 2005, 08:47 AM
First of all figure out what card you have there, and install the INTENDED software for it.
Then, if you're using the analog loop cable from the TV card straight into the sound chip's loopthrough, audio is always going to be delay-free. The video stream however, depending on how much deinterlacing and other trickery you apply to it, will have some delay, from one frame to quite a few. Audio will be "ahead of" video then.
The solution is to use the SAA713x chip's capability to feed audio through the PCI bus as well - that'll be perfectly in sync with the video feed through PCI. If your software of choice doesn't screw it back up, that is. |
May 23rd, 2005, 05:19 PM
I installed the software that came with it, so I guess I assumed it was the correct software. I am more concerned at this point about why the "line-in" isn't working. Any ideas? |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Can you run three monitors using a dual-head AGP card & a PCI card | Grog | Graphics Cards and Displays | 11 | July 18th, 2009 07:30 PM | | Gigabyte RADEON 9200 Video Card, better card for the money ? | Richard Cranium | Graphics Cards and Displays | 7 | January 26th, 2004 04:43 AM | | FS/T - Video Card - Sound Card - Custom Heat Sink / Fan | zepper | Traders Forum: Buy, Sell, Trade | 3 | June 9th, 2003 12:20 PM | | WTT 64mb S3 card for 32mb+ geforce 2 or 256 card | chris64 | Traders Forum: Buy, Sell, Trade | 4 | February 19th, 2003 11:11 PM | | Fact or Fiction: Never put a card in the slot directly below the video card. | FreakyOCR | Technical Support | 19 | December 15th, 2001 07:34 AM | |
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | | | | Most Active Discussions | | | | | Recent Discussions  | | | | | |
