Can't delete! help!!!
Currently Active Users: 2136
Discussions: 200,948, Posts: 2,379,385, Members: 246,309
Old June 2nd, 2005, 12:09 PM   Digg it!   #1 (permalink)
Autokad's Avatar
Exclamation
I have a Multi Cd-keygen for battle field that I was in the middle of downloading, when I stop it.
now,even though I uninstalled bf a long time ago,I can't delete the destop icon
the cd gen was never installed so I don't understand why I can't delete it
it says this when I try to delete it : Connot delete Multi Cd-keygen for battle field:It is being used by another or person or program
Close any programs that might be using the file and try again
Autokad is offline   Reply With Quote
Old June 2nd, 2005, 12:11 PM     #2 (permalink)
A hero in training
GroundZero3's Avatar
have your tried deleting it while in safe mode?
GroundZero3 is offline   Reply With Quote
Old June 2nd, 2005, 12:36 PM     #3 (permalink)
o, lol, that has actually happened to me before um, you might want to try rebooting or what groundzero suggested, it sucks, I know from experience....
I may be wrong though ::shrug::
Just for the record, I think its pretty neat your title matches your Picture groundzero
MrSuave is offline   Reply With Quote
Old June 2nd, 2005, 12:41 PM     #4 (permalink)
Autokad's Avatar
I've tryed rebooting doesn't help
I havn't tryed in safe mode yet....
Old June 2nd, 2005, 01:15 PM     #5 (permalink)
Millwright
stroyal's Avatar
Can you sign on as admin or another user with admin privlages and delete it in documents and settings?
stroyal is offline   Reply With Quote
Old June 2nd, 2005, 09:27 PM     #6 (permalink)
Autokad's Avatar
I'm already logged in has admin
Old June 2nd, 2005, 09:41 PM     #7 (permalink)
meese's Avatar
stroyal realizes that. The problem is you can't always delete files from the active user profile. So by creating another admin account and logging in to it, then drill down to the file located in your original admin account, you should be able to delete it.
meese is offline   Reply With Quote
Old June 2nd, 2005, 09:50 PM     #8 (permalink)
Autokad's Avatar
so I should create another admin acount and try and delete it then?
Old June 2nd, 2005, 09:57 PM     #9 (permalink)
meese's Avatar
If safe mode didn't work. Also I don't know what permissions are set on the file. I can't tell you for sure it will work. I've done it and it worked for me.
Old June 2nd, 2005, 10:05 PM     #10 (permalink)
noony's Avatar
noony is offline   Reply With Quote
What should I and Shouldn't I delete? Blackbullet Technical Support 7 October 17th, 2004 09:13 PM
delete riiix General Tech Discussion 9 September 14th, 2003 04:52 PM
delete me Urban_Squrill General Tech Discussion 1 August 21st, 2003 04:01 AM
Where does Win2KPro delete profile folders when you delete them from System Cntrol Pa Wolf23 Applications and Operating Systems 8 September 27th, 2002 12:19 PM
Making Health Care Worse (169)
The disrespect of Obama by Russian .. (21)
Is It Just Me? (2934)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Internet Lost (0)
Graphics Card Upgrade Questions (0)
Graphics Card Upgrade Question (2)
Asus P4G8X Mobo (6)
How to convert MP3's (2)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
