nVidia drivers problem [TV out?]
Currently Active Users: 1460
Discussions: 200,933, Posts: 2,379,167, Members: 246,297
Old June 12th, 2005, 06:37 PM   Digg it!   #1 (permalink)
Phibz//'s Avatar
Send a message via MSN to Phibz//
Hey,
Got a problem that i dunno how to solve,
I want to use the TV out function on my GeForce Fx 5700 graphics card, and it wont let me. Basically what happens is that if i restart my computer i can choose to use the tv, either as a clone or as a single display etc, however it only lasts for about 15 sec, even if i say that i want to keep these settings when the computer asks me. After this has happened ones it doesnt even give me the coice of using the tv at all!
Im at my grandmas for the summer so i havnt tried this using the available tv, it worked perfectly at my own apartment with my tv.
Anyone knows what this is due to? I have the latest nVidia drivers...
Thnx!
Asus A6JA Laptop // Centrino Dual Core @ 1.66 GHz | 1024 mb RAM | ATI mobility radeon x1600 256 mb // Mobility above all**
Phibz// is offline   Reply With Quote
Old June 12th, 2005, 07:10 PM     #2 (permalink)
Ultimas w00t! Mastah...
vikeor's Avatar
Send a message via MSN to vikeor
u should have the option to chose ur display in the advanced settings...
did u look there?
AMD Opteron 146 2.8ghz 280x10
1GB GEIL ONE S PC3200
DFI LanParty UT NF4 Ultra-D
ATI X1800XT @ 700/800
Enermax Noisetaker 485W
BigWater SE
vikeor is offline   Reply With Quote
Old June 12th, 2005, 07:15 PM     #3 (permalink)
Phibz//'s Avatar
course i did, but solved it by reinstalling the drivers =) thnx though
Old June 12th, 2005, 07:21 PM     #4 (permalink)
vikeor's Avatar
good job
New Nvidia drivers out! GroundZero3 Graphics Cards and Displays 30 April 5th, 2004 12:25 AM
Problem with Nvidia video drivers brunix Technical Support 3 November 24th, 2003 08:02 PM
What are the best Nvidia Drivers? cMoAyRoItOe General Tech Discussion 6 June 2nd, 2003 05:50 PM
Nvidia new drivers problem Top Gun Technical Support 9 February 28th, 2002 07:05 AM
NVidia drivers problem Top Gun Technical Support 40 January 9th, 2002 03:35 AM
Is It Just Me? (2875)
Obama the Muslim (14)
CPU fan stops spinning (0)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
