June 21st, 2005, 08:46 AM #1Junior Member
- Jun 2005
- 2
Please help - used the wrong charger on my laptop :-(
I'm a newbie to PC's, please advise:
Can anyone help please? I accidentally used the wrong power charger for my Compaq M700 laptop and now it will not switch on, even with the correct charger, and no lights saying charging. Is there any way I can fix this myself? what have I blown?
thanks in advance - hope someone can help
June 21st, 2005, 09:03 AM #2
Welcome to TechIMO!
Well, you have obviously fried something inside and there is no way I see that you can fix this yourself.
Sorry to say but it's going to have to be serviced.
Bill in SD, CA*****
The final legacy of the United States will be that in the end liberalism shamed & destroyed the heritage of this great nation. How sad as I see no turning back. When in Rome ..
June 21st, 2005, 09:09 AM #3
I suppose you could try pulling the battery and A/C power, let it sit a bit, hold the power button down to try to discharge power still in the sytem... also try it on A/C power with the battery removed.
But ya, it seems you have done irreperable damage to the power system if it wont power on at all.
June 21st, 2005, 06:17 PM #4Junior Member
- Jun 2005
- 2
Is it a costly thing to repair do you think?
June 21st, 2005, 06:30 PM #5
If its under warranty then probably not.
My other car is a T-34.
June 21st, 2005, 06:34 PM #6
June 21st, 2005, 06:36 PM #7
Not if you tell them what happened.
I would just say "it quit".“Those who desire to give up freedom in order to gain security will not have, nor do they deserve, either one.”
Benjamin Franklin
June 21st, 2005, 06:37 PM #8
Usually you have to pay extra for accidental damage coverage. Do you still have the warranty certificate?
June 21st, 2005, 06:47 PM #9
M700 is most likely out of warranty. Discontinued for at least 2-3 years.
How could wrong Amperage affect a laptop
By Undeadlord in forum General Tech DiscussionReplies: 34Last Post: July 20th, 2012, 08:22 AM -
Dell Laptop Problems - No Boot Sector+Incompatible XP Partition+Wrong HD Capacity??
By shuomaru in forum Technical SupportReplies: 6Last Post: November 30th, 2004, 06:20 PM -
New Laptop, wrong hard drive size?
By Bizkitkid2001 in forum Storage RelatedReplies: 2Last Post: July 27th, 2003, 03:09 PM
"What is the need for BCCI chief to step down? If some MPs take bribe, does it mean parliament should be closed," Shukla told TV channel CNN-IBN. Watch iron man 3 movie online download iron man 3...
Spot-fixing: Rajeev Shukla defends...
