Results 1 to 10 of 10
    Exclamation How To Print Folder Trees in Explorer
    Is there a way to print out the lists of folders and subfolders in microsoft explorer?
    you could expland the ones you need to see, and hit the print screen button. Then go into paint, crop the picture then print it.
    Ultimate Member rastorize's Avatar
    Jul 2002
    sacramento
    1,165
    I'm not sure if there's a way to print them - what I've done is the past is take a screenshot and then print the image.
    thank you
    ASUS A7N8x Mobo
    AMD Athlon XP 2600+
    9700 Pro Graphics
    Sound Glaster Audigy Gamer
    2 WD 120 GB HDD's
    2 512mb PC3200 Ram
    4 fans
    Austin 450 PSU
    Quote Originally Posted by Steve R Jones
    This is a way to print the contents of a folder...
    HOW TO: Add a "Print Directory" Feature for Folders in Windows XP
    SUMMARY
    This article describes how to add a "print directory" feature for folders in Windows XP. After you follow the steps in this article, you can right-click a folder, and then click Print Directory Listing to print a directory listing of the folder's contents.
    As usual, MS is VERY vague about implementing this. Ok, so I do all ther gunk it says to do, Then what?
    I suppose I have to reboot after I change the registry things?
    I see no new "print directory tree" in my shell
    BBIAM
    Athlon 4400+ XP/ASUS - M2N-E SLI Athlon/2GB Kingston 800 MHz DDR2
    NVIDIA GeForce 8400 GS (512 MB)/20x Lite-On DVD+-RW
    Sound Blaster Live 24 bit/Digidesign DIGI-001 (Works great still)/Pro Tools 6.4
    Well Whaddya KNow!
    IT WORKS!
    Pretty Cool!
    If you follow the BATCH file, it deletes the "listing" file after it prints- If you want to save the directory listing as text, remove the delete line, or add a line in the batch file to move the listing file to a folder where you want to save the listings.
    Supporting our military Bill in SD, CA's Avatar
    Oct 2002
    Camelot by the Sea
    10,069
    There's also PrintFolder 1.2
    All the way at the bottom is the free version.
    Bill
    The final legacy of the United States will be that in the end liberalism shamed & destroyed the heritage of this great nation. How sad as I see no turning back. When in Rome ..
    Jul 2005
    7
    This one will cost you $30 US but it is well worth it as it works better than any freeware program I've tried. It can save as a text file or send to printer. It is inserted in the right click context menu.
    Ultimate Member RayH's Avatar
    San Francisco, CA
    2,799
    I use a freeware directory printer from Karen Kenworthy. It works just fine..
    http://www.karenware.com/powertools/ptdirprn.asp
    RayH42450@gmail.com
    Please indicate you are from TechIMO in subject line so you don't get deleted as spam :)
    Jul 2005
    7
    The one from Karen inserts all kinds of useless characters in the file path. That's why I chose to pay for a good one instead.
  1. Open folder causes explorer crash
    By kjg in forum Applications and Operating Systems
    Last Post: March 9th, 2009, 02:06 PM
  2. print folder listing
    By stevemu in forum Applications and Operating Systems
    Last Post: August 23rd, 2004, 05:03 PM
  3. can't browse into certain folder (win explorer or DOS)
    By rh71 in forum Applications and Operating Systems
    Last Post: March 17th, 2004, 06:46 PM
  4. Windows XP Explorer Default Folder
    By Xeroid in forum Applications and Operating Systems
    Last Post: May 31st, 2002, 06:01 AM
  5. Default Explorer Folder in WinME
    By M_Six in forum Applications and Operating Systems
    Last Post: April 16th, 2002, 03:23 PM
