Thread: What power supply?
July 1st, 2005, 11:07 PM #1
What power supply?
I read JPMiller's guide on selecting a PSU and used the site listed to calculate my maximum watts at peak usage and it was 300 watts. So I'm looking for a 400-550 Watt PSU that has connectors for a PCI-e video card, and will be compatible with either the DFI LANPARTY UT nF4 Ultra-D ( http://www.newegg.com/Product/Produc...82E16813136152) or the MSI K8N Neo4 Platinum ( http://www.newegg.com/Product/Produc...82E16813130484 )
I checked out the OCZ Modstream 550watt on newegg ( http://www.newegg.com/Product/Produc...82E16817104155 ) and read a review, where they said everything was fine with it, comes with a 3 year manufacturer warranty etc. I'm just looking for a good quality (sparkle, antec) that will power my new PC which you can view @ http://www.techimo.com/forum/t145592.html
On the OCZ I only counted 20 pins on the connector to the motherboard, and both the DFI and the MSI use a 24 pin connector, I don't want to use an adapter as I feel you could possibly lose some wattage.
Thanks for all the help.DFI Lanparty UT nF4 Ultra-D
AMD Athlon 64 3000+ Venice
1GB Corsair VS
BFG 6800GT OC 256MB
Seagate 7200RPM SATA150 120GB
July 1st, 2005, 11:11 PM #2
Budget.
July 1st, 2005, 11:12 PM #3
Ocz all the way with the DFI board
When you're runnin' down my country, man
You're walkin' on the fightin' side of me
July 1st, 2005, 11:13 PM #4
Since you're looking to spend something in the ~100 range, I think this PSU would suit you best, and it has 24 pins, I counted
http://www.newegg.com/Product/Produc...82E16817103924
or this one:
http://www.newegg.com/Product/Produc...82E16817101516
July 1st, 2005, 11:15 PM #5
That has my vote, the Antec.
July 1st, 2005, 11:22 PM #6
I'm still in limbo between the msi or the dfi, dfi is the awesome overclocker, but so many people I know have recommended the MSI board, also what ram would you prefer
http://www.newegg.com/Product/Produc...82E16820146299
or
http://www.newegg.com/Product/Produc...82E16820145440DFI Lanparty UT nF4 Ultra-D
1GB Corsair VS
BFG 6800GT OC 256MB
July 1st, 2005, 11:24 PM #7
MSI has quite the compatibility issues, I'll tell you that, it didn't let me OC my CPU with Nvidia cards, and the 3dmark score with Nvidia cards is just a mess, while gaming is just like it's supposed to be. There's always a way around these bugs, but in some cases it may cost you $$$ on a new part in order to solve it or it may cost you a LOT of time because you would have to re-format your HDD to solve it.
bottom line:
DFI all the way
On the RAM, go with Corsair, better timings, better brand, same price- Corsair wins, hands down
July 1st, 2005, 11:27 PM #8Ultimate Member
- Mar 2003
- Location
- Kanada
- 1,044
Do not get a 500W PSU if you only need 300W at peak power. 400W is even a bit much, as you should probably be aiming around 350W. PSUs become less efficient (= more heat) when they run at wattages a lot lower than their rated maximum. Therefore, if you were running EVERYTHING under load, 300W on a 350W PSU would produce less heat than 300W on a 500W PSU.
If you plan on overclocking (meaning if you buy the DFI Mobo), then both of those rams suck. You need something that will compliment the motherboard and CPU (espically since you're getting a Venice), so you can push it up to its max.
July 1st, 2005, 11:30 PM #9
Well you have a point, but you're forgetting that PSUs also become less efficient when they heat up, so it's always good to have at least 50W more than your peak usage, and it's always good to have at least 100W more than peak for future upgrades
Just go all out now (on the PSU) so you won't have to buy another one on your next big upgrade
July 1st, 2005, 11:31 PM #10
The power supply is going to be supplying the 6800GT as well, so to be safe I would like to go with at least 400watt, can anyone suggest a 400watt psu from a reputable manufacturer with a 24 pin connector?
EDIT: I really like that Antec neopower, and nwo could you msg me on AIM, i added your UNDFI Lanparty UT nF4 Ultra-D
1GB Corsair VS
BFG 6800GT OC 256MB
July 2nd, 2005, 05:56 PM #11
July 2nd, 2005, 11:46 PM #12Thanks, I changed from the NeoPower to a similar PSU, but I changed quick and went ahead and ordered, but forgot to check the pin count and got a 20 pin, so as soon as it comes, I'm going to send it back and go for the smartpower 2.0, the one coming is the smart 1.0
Originally Posted by Reather
But I did go with the DFI board and the BFG 6800GTOC, hope I like it, well let you guys know how it runs.
1GB Corsair VS
BFG 6800GT OC 256MB
July 3rd, 2005, 02:54 AM #13The OCZ's are 24 pin.
Originally Posted by cal_woo[url
July 3rd, 2005, 12:42 PM #14you're right:
Originally Posted by mpc
http://www.newegg.com/Product/Showim...upply+-+Retail
July 3rd, 2005, 12:51 PM #15I must ask where you heard that as I can say I personally don't believe it...
Originally Posted by haxxorpoop
Intel D875PBZ mb, can only power on/off with rear power supply on/off switch
By mgugdec in forum MotherboardsReplies: 2Last Post: November 16th, 2004, 08:37 PM -
Find me a good power supply able to power my system.
By Bizkitkid2001 in forum General Tech DiscussionReplies: 23Last Post: October 20th, 2004, 07:14 PM -
Power Leak within Power Supply?
By mar122999 in forum General Tech DiscussionReplies: 0Last Post: April 21st, 2004, 11:37 AM -
Is there any way to test if the power supply is not giving enough power?
By flippery in forum General Tech DiscussionReplies: 13Last Post: November 4th, 2003, 12:30 PM -
Power/power supply problem
By jerrygarcia in forum Technical SupportReplies: 16Last Post: March 18th, 2003, 09:49 AM
ITS MY PARTY AND I CAN CRY IF I WANT TO! Rest day, that means 20 minutes of cardio in the am and pm! yay! Doing the Windows Azure training today, should be interesting since I work with AWS so...
