limewire problem  | |
August 15th, 2005, 07:45 PM
hey guys,
i was looking for a song on limewire(some rap song) and all the files i clicked, none of them had any sources, its been a while since this has been happening, any song i download wont have any sources. is this a problem with limewire, and should i switch p2p? is kaazaa lite still working and has recent songs??
thank you |
August 15th, 2005, 07:47 PM
What version of Limewire do you have?
I haven't had any problems, and I always have fast good connections. 50k +
-Blaze |
It works fine for me other than being flooded with bad files and infected files.
Benjamin Franklin
August 15th, 2005, 07:49 PM
August 15th, 2005, 07:55 PM
is it a recent version?
any suggestions??
August 15th, 2005, 08:37 PM
Limewire has always worked for me - no issues. Unlike Emule, Edonkey, Kazaa, Etc.. I have experienced a MUCH lower rate of purposely infected/altered files using Limewire. If you are dumb enough to blindly download and install anything over the internet you are begging to be exploited - ALWAYS scan your downloads.
SJG |
August 15th, 2005, 08:47 PM
yeah i do, but that isnt the question here
and i never download anything from the internet unless i know what it is
the question is: limewire isnt working for me
what p2p is best? and why isnt limewire working for me |
August 15th, 2005, 09:39 PM
| | Banned
limewire isnt that effective for most music (unless its something where its an entire cd as 1 song)
slsk is better suited for music needs |
August 15th, 2005, 09:40 PM
slsk you say?
ill give it a whirl |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Limewire | nwo75200 | Technical Support | 19 | January 16th, 2008 10:50 PM | | limewire probs | mbandela000 | General Tech Discussion | 1 | July 21st, 2005 08:17 PM | | limewire malfunction | james long | General Tech Discussion | 0 | June 15th, 2005 07:40 PM | | limewire problem | izaic3 | Technical Support | 2 | April 25th, 2004 02:31 AM | | Limewire 2.0 = virus? | Pshawn5 | General Tech Discussion | 1 | December 29th, 2001 05:15 PM | |
