Results 1 to 3 of 3
    Unhappy java applet doesn't work
    Hi all, i cant open any java applets on IE6. WHat's wrong? There's an X whenever there should be a java applet.
    Healdsburg, CA
    13,879
    In IE click on Tools > Internet Options > Advanced > Scroll down to Microsoft VM and make sure "JIT compiler for virtual machine enabled" is selected. If that doesn't do it you can download and install the Sun Java software. They have full instructions on how to install it.
    thx 4 da website. i downloaded it n that solved the problem
  1. Webcam Java Applet
    By implexant in forum General Tech Discussion
    Last Post: February 14th, 2005, 04:37 PM
  2. Java applet not starting?????????
    By Dooin' it in forum General Tech Discussion
    Last Post: August 6th, 2004, 03:54 PM
  3. Sun Java plugin refuses to work with IE6
    By felixz in forum Applications and Operating Systems
    Last Post: February 4th, 2004, 02:54 PM
  4. CheckOut my applet!
    By Tekk in forum Web Design, Development, Graphics, Photography
    Last Post: May 14th, 2003, 08:02 AM
  5. disable scripting and java applet
    By Howard I. No in forum General Tech Discussion
    Last Post: September 29th, 2002, 10:17 AM
