Building a Computer
Currently Active Users: 1949
Discussions: 200,920, Posts: 2,379,085, Members: 246,289
Old August 27th, 2005, 03:17 AM   Digg it!   #1 (permalink)
krosangnomelord's Avatar
Exclamation
Building a Computer
I've ordered all my parts on newegg, and that's a final decision. All I need to know, is if these parts are all compatible please:
http://www.newegg.com/Product/Produc...82E16837102151
http://www.newegg.com/Product/Produc...82E16819104241
http://www.newegg.com/Product/Produc...82E16820141164
http://www.newegg.com/Product/Produc...82E16813135151
http://www.newegg.com/Product/Produc...82E16811129150
http://www.newegg.com/Product/Produc...82E16827131256
http://www.newegg.com/Product/Produc...82E16822144102
And on top of that, I already have a video card here at home, and here are it's specs:
GeForce FX-5900 AGP 128 MB DDR-850MHz
krosangnomelord is offline   Reply With Quote
Old August 27th, 2005, 03:36 AM     #2 (permalink)
I'm silently judging you
ArcticFox's Avatar
Send a message via AIM to ArcticFox Send a message via MSN to ArcticFox Send a message via Yahoo to ArcticFox
Yep, should go together OK as long as that ECS thing doesn't go bunk on you...
ArcticFox is offline   Reply With Quote
Old August 27th, 2005, 03:38 AM     #3 (permalink)
could you tell me why it would go "bunk" on me?
Old August 27th, 2005, 03:41 AM     #4 (permalink)
DarkStar02's Avatar
Yeah those are all compatible, but from what I've heard the Sempron AMD CPU's are like the Celeron Intel CPU's, meaning they aren't very good. It's a steady build but I don't think you're going to be gaming on this machine.
My PC:
37" 1080p Sceptre LCD - ASUS VENTO Case - 500w Ultra PSU - P5B Deluxe - e4300 @ 3.4ghz - 4GB DDR800 - VistionTek HD3870 - Plantronics DSP-500
DarkStar02 is offline   Reply With Quote
Old August 27th, 2005, 03:48 AM     #5 (permalink)
XxCowOfChaosxX's Avatar
Send a message via AIM to XxCowOfChaosxX
He won't be gaming with that FX5900 either.
XxCowOfChaosxX is offline   Reply With Quote
Old August 27th, 2005, 03:48 AM     #6 (permalink)
well i was hoping to be gaming on it. i don't wanna spend more money that i am already
Old August 27th, 2005, 04:04 AM     #7 (permalink)
proffit's Avatar
dont listen to them the 5900 is a decent card by todays standerds. before i got my sli rig and my 6800's i was useing 5900's and with a little oc'ing i was able to play doom 3 @ 1024 with every thing on the highest detail with 4x aa and AF and still be pulling of 40+ ps and around 30ish for big fire fights. granted i was ocing the card so that it was giveing a 9800 xt a run for its money. dispite what is said with a little ocing you will have no problems with the games that are out today.
as for the semperon they arnt like the celeron. they were designed as budget cpu's and to continue the socket a (almost dead now) and the socket 754 while the 64bit chips ran on the 939 socket. the semperon is alot faster then the celeron and isnt fair to compair it with one. the cpu will run about in par with the intell 2.6ghz if not the 2.8ghz.
as for the ECS mobo well its a budget pc so you cant expect the world of it...
that said looks fine to me
if it is not broken, play with it till it is.
proffit is offline   Reply With Quote
Old August 27th, 2005, 04:12 AM     #8 (permalink)
ty for your very helpful post
Old August 27th, 2005, 10:51 AM     #9 (permalink)
andy1984's Avatar
Its fine for a budget build. The 5*** series werent nvidias strongest line, but you can always change that out in the future, the 6600gt's are likely to become nicely cheap within the next 6 months so keep a look out.
andy1984 is offline   Reply With Quote
Old August 27th, 2005, 11:24 AM     #10 (permalink)
beastgreeley's Avatar
I've got a FX5900nu, and it works fine for games, HL2, BF2,etc.(my son's machine)
Old Cranky and hard of hearing
Q6600@2.4ghz
Powercolor HD 3870 X2
beastgreeley is offline   Reply With Quote
Building a new computer -Sinister- General Tech Discussion 7 August 23rd, 2005 09:41 PM
Help building my first computer! the natrix General Tech Discussion 27 April 28th, 2005 09:32 AM
Building computer now -FMA General Tech Discussion 20 December 13th, 2004 07:16 PM
Building a computer postalone Motherboards 10 December 26th, 2003 08:59 AM
Building New Computer Shabow General Tech Discussion 13 April 23rd, 2003 07:37 AM
Is It Just Me? (2854)
Obama the Muslim (13)
radeon x850xt platinum & shader 3 (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
