Results 1 to 11 of 11
    Registered User EpyonMelee's Avatar
    Apr 2004
    2,149
    Compression questions for Music
    well, i just got a 512 MB SD card for my Tungsten E2.
    and well, what would be the best way to maximize space for music.
    ive seen some of my songs are variable bit rate, id assume that saves space?
    how can i make some small mp3s without losing quality, thanks.
    Real gangstas sip on Yacc jkrohn's Avatar
    Suckas-ville
    4,554
    You most definately want to use a variable bit rate over a constant bit rate. What formats does the Tungsten accept?
    Jkrohn
    Signatures blow hard
    Apr 2004
    2,149
    as far as i know, only Mp3s.
    id guess some other formats too
    Newbie filipino's Avatar
    May 2004
    Philippines
    3,922
    try ripping your music to mp3 format in 92bit using musicmatch or other similar software.
    I miss Dimebag Darrell
    Apr 2004
    2,149
    but will the sound be crappy?
    im searching, but coming up with only Mp3s.
    May 2004
    Philippines
    3,922
    nope, 92bit is also near CD quality. i mean for a portable device.
    Apr 2004
    2,149
    so how much would a ~4.00 minute song be with 92bit? i mean size-wise
    practically canada. bombledmonk's Avatar
    Aug 2003
    MN
    3,384
    Quote Originally Posted by EpyonMelee
    between 2-3MB
    I personally think 96kbs sucks big time. Almost anyone can tell the difference between 128 and 96.
    Apr 2004
    2,149
    2-3 MB sounds good to me.
    is the difference really noticable
    May 2004
    Philippines
    3,922
    oppss sorry its 96bit i mean
    for portable device? i don't think sound difference would be noticable.
    May 2004
    Philippines
    3,922
    for a 4 min. track file size should be 2.76 MB
  1. Embedded music question...html source copy & ripping music
    By *boom!* in forum Graphic Design and Digital Photography
    Last Post: April 26th, 2005, 04:49 PM
  2. Compression
    By nwo75200 in forum Multimedia and Audio
    Last Post: April 18th, 2005, 05:17 PM
  3. In need of a compression utility
    By Dark_Link2135 in forum Applications and Operating Systems
    Last Post: March 11th, 2004, 08:47 AM
  4. compression on calculators?!¿
    By fluffycow in forum General Tech Discussion
    Last Post: October 2nd, 2002, 04:44 PM
  5. File compression
    By mad1 in forum General Tech Discussion
    Last Post: June 18th, 2002, 02:54 PM
