Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 69
Thread: My first build
    Reaper him61's Avatar
    Jul 2005
    4,904
    2
    My first build
    ok, this is my 1'st build, and I tried to get the best stuff for the $$. So, if anything is like, not good, tell me. Any suggestions for better parts at around the same price would be helpful.
    Here it is:
    CPU:Athlon 64 3500+ Venice $219.00
    Mobo: DFI LANPARTY UT NF4-ULTRA-D $129.00
    RAM:Gigaram 2x1GB DDR466 (PC3700) $200.00
    Video Card:eVGA 7800GT $369.00
    OS:Windows XP Home w/ SP2 $91.95
    Case:ePOWER warrior w/ 450W PSU $74.99
    I've already got a hard drive, and everything else I don't think contributes much as far as performance goes. And one more question, does newegg deduct from the shipping costs if you buy like a lot of items?
    thanks.
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,195
    4
    I am unsure as to whether that psu will be sufficient. Epower is a good company (the tagan line atleast) but when searching through the site i couldn't find anything on the PSII450W psu that comes with the case.
    I wouldn't trust it with those components, it could be good but until i'm supplied with info on it, i don't trust it.
    Jul 2005
    4,904
    2
    The mobo is supposedly the best OCing one on the market
    Nov 2004
    Burning in Florida
    15,195
    4
    Quote Originally Posted by him61
    yea, a few members here have that board and have had great luck with it.
    Jul 2005
    4,904
    2
    The whole thing plus shipping will be ~$1,300. I dont know about anyone else here, but I think that that's ridiculus
    Nov 2004
    Burning in Florida
    15,195
    4
    http://www.techimo.com/forum/t152396.html
    check out how much he is spending...
    Jul 2005
    4,904
    2
    Ridiculus as in I can't belive I'm paying so little for something of that magnitude
    Senior Member lukesparksoff's Avatar
    Aug 2004
    Chicago
    867
    change the Ram to something with a Cas Latency of 2 instead of 2.5 .
    2gig is over kill save the money get 1gig you can always buy more later
    Get some articsilver5 great stuff
    PSU is one of the most important component shop real hard for a good one ,a bad one will hold your CPU and your GPU back(don't be cheap you get what you pay for)
    Shop for a good case your looking for good air flow ,can you add fans easyly
    eVGA 256-P2-N376-AX Geforce 6800GT 256MB 256-bit GDDR3 PCI Express x16 Video Card - Retail $299 is a better match for your system ,But don't listen to me who I'm I ,7800 are great ,7800GTX are better
    Jul 2005
    4,904
    2
    The case I'm getting has lots of room for fans, and what kind of PSU would you suggest?
    Nov 2004
    Burning in Florida
    15,195
    4
    2 gig is NOT overkill anymore. ever play BF2 luke? makes a noticeable difference there.
    why would you tell him to get a lesser video card?
    Jul 2005
    4,904
    2
    My 2nd choice of memory was these:
    http://www.mushkin.com/doc/products/...ail.asp?ID=198
    Nov 2004
    Burning in Florida
    15,195
    4
    that is extremely good memory, you will need to pumping a lot of volts through it though to make it perform at it's best.
    Jul 2005
    4,904
    2
    Which should I chose though?
    Aug 2004
    Chicago
    867
    I like this one $89
    http://www.newegg.com/Product/Produc...82E16817103930
    I like antec but I know there is some knock off just as good and cheaper,The one above have 2 12V-18A rails (you need at least 450W for a 7800) you need 450W or above with 24A or above on the 12V rail
  15. #15
    Nov 2004
    Burning in Florida
    15,195
    4
    It all depends, 2gigs does have it's definite advantages, and with pc3700 you will be able to get a pretty good OC' out it.
    It all depends, i'm assuming your a heavy gamer first of all, in that aspect 2gigs would be better. BUT it also depends on how much you are going to overclock..?
    The second memory is all around better memory, but 1 gig isn't enough for certain games to run to the fullest regardless of the rest of the specs of the comp
  16. #16
    Aug 2004
    Chicago
    867
    Quote Originally Posted by SoloCamo
    to me it was a better choice for his system I told him not to listen
  17. #17
    Jul 2005
    4,904
    2
    I'm gonna be gaming night and day, and OC'ing it to the limits.
  18. #18
    Jul 2005
    4,904
    2
    Oh yeah, another question, 4 80mm fans, or 1 120mm?
  19. #19
    Aug 2004
    Chicago
    867
    New build
    Don't buy anything you don't need right now
    Don't buy anything you going to have to upgrade later buy the up grade now(don't waste money)
    you just want get this thing off the ground up and runnning because prices drop everyday
  20. #20
    Jan 2003
    Milwaukee, WI
    7,657
    beyond the fact I think the case is a little guady/cheezy... the included PSU IS garbage...
    Buy a case separately and get a GOOD PSU...
    my suggestions if thats your taste in cases...
    http://store.yahoo.com/amamax/ogblatxmigac.html
    http://store.yahoo.com/amamax/susasiatcaen.html
    http://store.yahoo.com/amamax/mgenisiatxga.html
    PSU wise... I would go with something with a dual +12V rail..
    http://www.newegg.com/Product/Produc...82E16817104953
    http://www.newegg.com/Product/Produc...82E16817104936
  1. What do you think of this build?
    By eminem_rh25 in forum General Tech Discussion
    Last Post: December 24th, 2004, 07:26 AM
  2. to build or not to build, that is the question...
    By cyphen in forum General Tech Discussion
    Last Post: April 5th, 2004, 01:53 AM
  3. First Build
    By Bertus02 in forum General Tech Discussion
    Last Post: March 11th, 2003, 12:28 AM
  4. To build or not to build?
    By Agent_Embryo in forum General Tech Discussion
    Last Post: February 8th, 2003, 12:25 AM
