Results 1 to 4 of 4
    Member jpiermarini's Avatar
    Mar 2005
    Massachusetts
    428
    sound card issue with windows 98 in vmware
    ok. i'm sure this is an easy fix, but its 2 in the morning and i really have no ideas at the moment. sound card is integrated with the motherboard. the motherboard is a chaintech mpm800-3 http://www.chaintechusa.com/tw/eng/p...o=13&PISNo=315
    now i'm in vmware and running under my windows 98 setup, i go and check the system devices and it lists the sound card as not having drivers installed for it. no i know that vmware has a setting for the soundcard, but my assumption is that i have to have the drivers installed in windows 98 for vmware to be able to figure it out. however, chaintech is so wonderful that they don't even have any drivers for thier on board stuff. bunch of jerks. makes me wonder why i went with chaintech anyways. any ideas? cause i'm fresh out.
    (AKA) Nakamura sweeper2's Avatar
    Nov 2003
    5,737
    http://www.chaintech.com.tw/tw/eng/D...o=15&PISNo=315
    see if that helps...
    Mar 2005
    Massachusetts
    428
    thats odd i could only find those vga drivers before, however the audio drivers link doesn't work. perhaps i will email chaintech
    Mar 2005
    Massachusetts
    428
    i was however able to find the drivers on another page and when installed in the windows 98 session it says it can't find those chips/.
  1. A weird issue with the sound card
    By bloodybunny in forum Multimedia and Audio
    Last Post: August 5th, 2005, 04:45 AM
  2. Replies: 2
    Last Post: July 14th, 2005, 01:50 PM
  3. sound card issue
    By sevenal in forum Technical Support
    Last Post: November 30th, 2003, 02:49 PM
  4. Where to find alternate sound card drivers for Windows XP
    By Lonewolf54 in forum Applications and Operating Systems
    Last Post: July 23rd, 2003, 04:33 AM
  5. Does this sound like a video Card issue?
    By Steelysteel in forum Graphics Cards and Displays
    Last Post: July 19th, 2002, 11:14 PM
