Help with picking parts  | | |
October 12th, 2005, 06:07 PM
| | Moderator
October 12th, 2005, 06:26 PM
| | Full Time WoW Addict
You're one sick, powerhouse freak!
That's basically all I have to say about that
j/k
ok, here goes....
Why are you going with s940 instead of 939? I mean if you're a gamer and looking towards the future, I would go with an X2 instead.
But I hear that Opertons run really cool and are OC freaks, so that should be good
I really don't like the whole 4GB RAM idea, I think it's overkill, but it would be great if your mobo and CPU fully supports it. What I mean by that is that you should make sure that when you put all those 4 sticks in there, most likely they're going to downlock to ddr266 or ddr333 speeds with 2T timings, that's what happened to me, there's nothing you can do to fix it. As long as the 4GB will work and play nice with your CPU & mobo, I see no reason why not to go for it, even though I think that 2GB is optimal these days.
For the case, I would recommend a Lian-Li with the removable mobo tray, and also because it's aluminum so it should keep stuff cooler
I'm not too sure about that PSU though :/ Got a link to it?
You really don't need an overkill PSU, your system won't use much more than 24A from the 12v rail, which is less than 300W under full load. A nice 400-500W PSU with dual rails would be nice.
__________________ -NWO® ---6000 point club-----
A64 X2 4600+
2x512MB Geil DDR500
2x512MB Kingmax DDR500
@DDR266 speeds
Sapphire x1900GT |
October 12th, 2005, 06:28 PM
| | Moderator
Well I looked around for a base system by building stuff from VoodooPC and Alienware and then started looking around from there, lemme go look at other 939 Mobos, do they support Dual CPUs and all that good stuff?  |
October 12th, 2005, 06:35 PM
OK, so now that you have the links in I can conclude that obviously your mobo will support the RAM, and so should your CPUs, after all, they are server CPUs created to handle well over any desktop RAM limit.
That PSU also looks very fancy, looks like it's a 650W PSU (most PSUs use their ratings as max output or somewhat close). Looks very good, top notch, without a doubt.
s939 does NOT support dual CPUs, there are no s939 dual CPU mobos, and there probably never will be. |
October 12th, 2005, 06:37 PM
Well if you need alot of power for rendering, why not go with intel? |
October 12th, 2005, 06:43 PM
| | Moderator
Well I have gone with intel before but AMD seems to have the price right and the proper idea with Dual CPUs. I am switching the RAM to ECC and buffered, I was informed that is a good idea and or requried. |
October 12th, 2005, 06:49 PM
Oh yeah, last time I checked, s940 only uses ECC buffered RAM
It's probably a good move by you that you switched it
Note that ECC RAM is a bit slower.... at least it was when I checked out this Corsair explanation on RAM: http://www.corsairmicro.com/corsair/...707/index.html
Long, and possibly boring as well as annoying, but very useful nonetheless. |
October 12th, 2005, 07:12 PM
| | SoMuchAnime-SoLittleTime
My only question...why are you going with a 7800 GTX? |
October 12th, 2005, 07:18 PM
| Quote: |
Originally Posted by EXreaction My only question...why are you going with a 7800 GTX? | My only question for you.... why not? |
October 12th, 2005, 07:19 PM
| | Moderator
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Parts, Joysticks, mobo, mem and more parts | DAVEW0670 | Traders Forum: Buy, Sell, Trade | 1 | February 17th, 2004 11:17 AM | | i need some help on picking the right processor | daniel brooks | Motherboards | 9 | June 28th, 2003 04:01 PM | | Picking Up The Edsel! :) | nochay | IMO Community | 25 | January 30th, 2003 02:27 PM | | Help picking out a new MB | saxgod | Motherboards | 10 | December 17th, 2002 06:32 PM | | I need your help picking out a cpu. | batmeat | Processors, Memory, and Overclocking | 9 | January 11th, 2002 03:57 PM | |
