not booting
Currently Active Users: 1938
Discussions: 200,919, Posts: 2,379,079, Members: 246,287
Old October 23rd, 2005, 05:45 AM   Digg it!   #1 (permalink)
Angry
not booting
hi im new, I have a compaq deskpro en, I am running win98se, I was trying to tidy up my hd and the roof fell in. it will not boot from a: bootdisk or the cd, I went into the bios and changed the boot order to A: 1st still nothing I put cd 1st nothing, I get the following messages, 1782 disk controler failure, media test failure, vfat device initional failure, I ran norton anti virus it found manny junkie virus and repaired then, it said could not repair win.vi9.
so what can I do thanks jim.
Last edited by jimhel : October 23rd, 2005 at 05:47 AM. Reason: word not correct test not text
jimhel is offline   Reply With Quote
Old October 23rd, 2005, 06:15 AM     #2 (permalink)
Ultimas w00t! Mastah...
vikeor's Avatar
Send a message via MSN to vikeor
Welcome to TechIMO!
what do u mean "the roof fell in" ??
AMD Opteron 146 2.8ghz 280x10
1GB GEIL ONE S PC3200
DFI LanParty UT NF4 Ultra-D
ATI X1800XT @ 700/800
Enermax Noisetaker 485W
BigWater SE
vikeor is offline   Reply With Quote
Old October 23rd, 2005, 07:01 AM     #3 (permalink)
It's the cheese guy! ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
Unplug the hard drive, then see if it will boot from floppy or cd.
paul9 is offline   Reply With Quote
Old October 23rd, 2005, 07:43 AM     #4 (permalink)
Originally Posted by vikeor
Welcome to TechIMO!
Old October 23rd, 2005, 07:45 AM     #5 (permalink)
paul9 I tryed that still not booting, the a: drive lights up and it whers? a couple of seconds then stops, ho hum.
Old October 23rd, 2005, 08:54 AM     #6 (permalink)
paul9's Avatar
Try a cd such as Ultimate Boot CD.
http://www.ultimatebootcd.com/
http://www.ubcd4win.com/
Remember to burn the ISO file to cd using the Burn DISC IMAGE option of your burning software, otherwise you will end up with an unbootable cd.
You could also try making a new boot floppy on a different machine. Try at www.bootdisk.com. if you can't find a machine you can make a boot floppy on.Use a fresh, new floppy disc, and use a floppy drive cleaner disc on the drive before you retry, if you go with floppy booting.
What cd did you last use to try to boot from? Most discs are not bootable.
Old October 25th, 2005, 03:35 AM     #7 (permalink)
wera's Avatar
Send a message via AIM to wera Send a message via MSN to wera Send a message via Yahoo to wera
roof???
wera is offline   Reply With Quote
Old October 25th, 2005, 08:53 AM     #8 (permalink)
still no boot
For everyone that is not sure what is ment by "the roof fell in" it is an old saying ment to explain that things have gone haywire.
I am still looking for an iso file that will not take about 3 hours to down load, I am not on broad band, dial up is slow, can anyone help.
jim
Old November 9th, 2005, 06:37 AM     #9 (permalink)
I am now booting but
I have at last loaded windows 98se, this means that the boot from the a: drive found my cdrom, now when I try to use the cdrom it says no cdrom connected to this computer I have a program vxd.fix that will replace any lost damaged files but I need the C; and cdrom to use it what can I do to get my cd working, thanks to all that helped in the past. jim
Help with new pc booting :( darick General Tech Discussion 7 September 29th, 2005 04:51 AM
XP not booting up...help! efete Applications and Operating Systems 3 March 30th, 2005 02:17 AM
It's not booting! DanGrease Technical Support 14 January 5th, 2005 10:14 PM
Booting your PC: Theophylact IMO Community 1 September 29th, 2003 11:16 PM
Booting the O/S batmeat Applications and Operating Systems 3 December 30th, 2002 07:26 PM
Is It Just Me? (2850)
Obama the Muslim (13)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
