Installation File ERROR: Help!!
Currently Active Users: 1563
Discussions: 200,954, Posts: 2,379,487, Members: 246,325
Old October 27th, 2005, 09:02 PM   Digg it!   #1 (permalink)
ProCompBuilder's Avatar
Send a message via AIM to ProCompBuilder
Exclamation
I'm having a problem uninstalling BF42. There is no icon for it, and no files under EAgames except for BF2 ones. So when I go to remove programs, there is a small computer with a disk with it that says BF42, but its only 0.62mb in size, and when I clikc it to uninstall it it says:
"An installation support file could not be installed. they system cannot find the file specified."
If anyone can help, that would be great, thx.
u either shoot, or get shot at..................by me
ProCompBuilder is offline   Reply With Quote
Old October 27th, 2005, 09:11 PM     #2 (permalink)
have you tried reinstalling, then uninstalling it? does the game play? do you know what directory its in?
AMD Athlon 2200+@1.930Ghz(It's OC'd to a 2400)
768MB PC3200 DDR-SDRAM| 278gb(3 hdd)
nVidia 6200 256MB AGP gfx card
XriotsuX is offline   Reply With Quote
Old October 27th, 2005, 09:25 PM     #3 (permalink)
k thx, i managed to fix it. I put in the CD, went into my computer, then right clikced the BF disk and hit search, and found a file that was corrupt and deleted it, then found the original uninstall file and it worked. Thx though.
Old October 27th, 2005, 11:38 PM     #4 (permalink)
....well im glad anything i said might have helped
CRC installation error matthewd Technical Support 3 September 14th, 2005 05:57 AM
Nvidia Installation Error Iturea Linux and Unix 5 August 19th, 2005 09:56 AM
installation error over ftp SKYLINEGTR33MWJ Linux and Unix 4 January 10th, 2005 05:47 PM
Answer file for installation muno General Tech Discussion 4 April 7th, 2004 02:37 AM
error prevents installation of XP :( thunderbt3 General Tech Discussion 4 August 13th, 2002 12:47 PM
Is It Just Me? (2944)
Print spooler problem (15)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
