Results 1 to 16 of 16
    Senior Member lablkilz699's Avatar
    SF Bay Area
    953
    Kill Disk Not Working
    ok...i just built a computer for my friend but we are using his IDE hard drive out of his old computer....i made a kill disk bootable floppy and powered up the computer...everything works right but when i put in the floppy and restart kill disk stuff never goes....
    it just keeps trying to boot the old copy of windows to the last know good configuration.....
    I made sure the floppy was the first bootable drive.
    what could be the problem??
    Macbook Pro 15"
    23" Apple Cinema Display
    Ultimate Member twistedbrntucker's Avatar
    Aug 2002
    Cincinnati, Ohio
    2,016
    Are you trying to reformat and do a clean re install of Windows?
    Work hard to become not to acquire. I didn't work hard to win a million dollars, I worked hard to become Winston Cup Champion. Alan Kulwicki 1992
    Ultimate Member Jarhed7276's Avatar
    Apr 2003
    Texas
    2,230
    Can the floppy drive read other disks?
    Have you tried booting from another boot disk then running Killdisk?
    SF Bay Area
    953
    yes, trying to reformat, clear the hard drive and install a fresh copy of windows.
    im pretty sure the floppy can read other disks....i mean i dont know why it wouldnt be able to, it was in a computer before this where it worke? i rechecked all the IDE cables and power.
    how do i boot from another bootdisk and then run killdisk?
    Macbook Pro 15"
    Senior Member Foggy's Avatar
    CCC by the Sea
    857
    Do you have a copy of the ultimate bood CD (http://www.ultimatebootcd.com/) if not D/L it KillDisk is on it
    You can't get there from here
    SF Bay Area
    953
    umm....it just has a link to killdisk....what boot cd should i choose? tell me specifically which thing to download from this page...
    http://ubcd.sourceforge.net/
    Macbook Pro 15"
    CCC by the Sea
    857
    SF Bay Area
    953
    okay.....the .exe or the zip or what??
    will it be able to open a a exe without windows? a zip?
    Macbook Pro 15"
    SF Bay Area
    953
    am i going to burn whatever is in the zip to a cd and then turn on the new computer, put the cd in, press restart, then it should boot to something where i can put in the kill disk floppy and get it to work?
    Macbook Pro 15"
    SF Bay Area
    953
    bump.
    Macbook Pro 15"
    CCC by the Sea
    857
    No need for a floppy, killdisk is on the Ultimate Boot CD so boot with CD and look under disk utilities.
    SF Bay Area
    953
    so i just downloaded the "full version" zip file. should i just extract the contents of the zip to a cd basically and when i put it in the computer it should boot to the cd?
    Macbook Pro 15"
    CCC by the Sea
    857
    You got it! Just make sure the BIOS is set to boot from CDROM
    SF Bay Area
    953
    okay.......i copied the contents of the zip folder to a cd.....no cigar...didnt do anything....just went straight to the "boot to last good known configuration of windows" and whatever and just sits there......
    Macbook Pro 15"
  15. #15
    Apr 2003
    Texas
    2,230
    labl, see if this method will work for you.
    Download the Win98SE OEM bootdisk here: http://www.bootdisk.com/bootdisk.htm
    Put a blank floppy into the drive and run the bootdisk program. It will make a boot disk for you.
    Change your BIOS to boot floppy first and boot from the disk. Once you are at the A:\ prompt remove the bootdisk and insert the killdisk. Type in killdisk at the A:\ prompt.
    See if kill disk will run this way.
  16. #16
    SF Bay Area
    953
    okay, going to try that now...i heard this board was set in default raid setup so i checked and i disabled it.
    still nothing works.
    the guy who im building it for ordered a new SATA 80GB drive...im hoping that will work when he gets it but still...id rather this hard drive work as well.......
    anyways.....going to try the bootdisk thing....
    also....could it possibly need a BIOS flash?
    Macbook Pro 15"
  1. Kill disk on Laptop with external FDD
    By first_major in forum General Tech Discussion
    Last Post: September 9th, 2004, 07:16 AM
  2. how to burn kill disk
    By sr71000 in forum Storage Related
    Last Post: August 11th, 2004, 10:24 PM
  3. Militants Kill 5 Westerners Working in Saudi Arabia
    By Theophylact in forum IMO Community
    Last Post: May 3rd, 2004, 04:11 PM
  4. Kill Kill logon/off splash screen
    By Gait_Keeper in forum Applications and Operating Systems
    Last Post: January 4th, 2004, 11:53 PM
  5. Replies: 13
    Last Post: December 20th, 2001, 10:49 PM
