Thread: Corrupted Print spooler
December 14th, 2005, 06:47 PM #1Junior Member
- Dec 2005
- 4
Recently went through massive spyware and adware problems. Took care of most of the issues using adaware and spysweeper along with yahoo security. But it appears the "print spooler" function is corrupted somehow and I cannot manually turn back on. I am not able to print anything.
What do I do?
December 15th, 2005, 06:43 PM #2Banned
- Dec 2005
- 1,465
If you could provide a little detail on the operating system as well as make, model, and the
type of printer you are using it would be a big help in determining what is needed.
December 15th, 2005, 07:00 PM #3
And when you try and print what is the actual error message you receive?
December 15th, 2005, 09:19 PM #4Banned
- Dec 2005
- 1,465
http://support.microsoft.com/kb/q191949/ for 95, 98, and ME printer spool32 errors.
http://www.measureup.com/testobjects...4W/5a8d03b.htm deals with solving printer
spooling problems.
There are a few tips there. Another method is to go into the control panel to locate the
printer and faxes section. Once in there you can see if a print job is hung. Sometimes a new
print job fails when the system registry gets effected by a virus or spyware like you have
described here. If you can post a log using the HiJackThis utility there may be a fix that can
be offered in the security section of this forum.
The alternative pain is to remove all of the printer software to have Windows redetect the
printer itself for a reinstallation of everything. Windows then asks for the driver disk. After
that you would then have to reinstall the printer software and hope all goes well. Here's a
link for the HiJackThis analyser and tutorial. http://www.techimo.com/forum/t137826.html
The first post has the links for the analyzers and tutorial.
December 17th, 2005, 10:48 AM #5Junior Member
- Dec 2005
- 4
Thank You for reply
Windows XP
Lexmark Z605
Tried reinstalling printer driver but get this error (also get this error when I try to manually start print spooler through...control panel, admin tools, services, print spooler)...
Error 1068: Dependency service or group failed to start
December 17th, 2005, 11:26 AM #6Junior Member
- Dec 2005
- 4
Well, Before I removed all of the print software and went to print the message was "print spooler not started, start now?". clicked yes to that but get error message...Could not start on local computer. Error 1068:dependency service or group failed to start.
Now I cannot reinstall the print drivers because the print spooler is not started and cannot be started manually via control panel, admin tools, services, print spooler.
This is more difficult of a problem than it seems.
December 17th, 2005, 09:44 PM #7Banned
- Dec 2005
- 1,465
Now you have to be more thorough with the antivirus and antispyware scans because the
problem here seems to have more to do with the system registry. Another way to verify if
all MS services are being loaded properly is found by using the msconfig utility to go to the
next to last tab, not the startup group there. Usually you would check the hide all ms serv.
box to hide the MS defaults if trying to disable a bad software. Here you want to examine
the MS services to see if they are all enabled. The RPC does have to be started.
What is the RPC? The remote proceedure call as it is referred to. If you have administrative
access on the system, go to the admin icon in control panel and click on services. There you
can scroll down to the RPC and right click on it if that is not currently running. The menu has
a recovery tab where instruction to restart the system will be listed as part of enabling it.
Give this a quick look to see if this can get you going. If not we'll find something that does.
March 25th, 2008, 08:10 PM #8Junior Member
- Mar 2008
- 1
Having Printer Problem Too
I have a Toshiba eStudio e3100c office printer/copier that won't install on only one out of 6 computers in the office. Whenever i try to install it an error that reads Error on completing task. And after that, the print spooler stops working. Restarting the spooler doesn't do anything because it just stops again. However, when i manually delete the incomplete driver folder from the drivers folder under spool, the error no longer occurs. What do you guys think could be causing this? The PC it won't install in is an exact replica of another PC it successfully installed in.
Vista business, 2gb of RAM, intel celeron processor, spysweeper, trend micro antivirus, latest updates have been installed. Please help!!!
Print Spooler
By Arizona_kay in forum General Tech DiscussionReplies: 9Last Post: December 14th, 2005, 06:51 PM -
spooler.exe
By nettizen in forum Applications and Operating SystemsReplies: 5Last Post: June 4th, 2005, 04:01 PM -
spooler subsystem app trying to access the internet
By rande in forum Technical SupportReplies: 3Last Post: February 21st, 2004, 10:00 PM -
print from linux to stand-a-lone print server
By Rico Mania in forum Applications and Operating SystemsReplies: 0Last Post: October 11th, 2003, 04:57 AM -
Lexmark x83 - new print cartridge, but no print shows up
By xmradio in forum Technical SupportReplies: 1Last Post: June 28th, 2003, 10:58 PM
Is this full manufacturing production, or just some assembly?
Apple Confirms Mac Production in...
