PSU wattage
Currently Active Users: 2297
Discussions: 200,942, Posts: 2,379,291, Members: 246,305
Old December 16th, 2005, 05:09 AM   Digg it!   #1 (permalink)
PSU wattage
I did a wattage calculator on the net for my system and it come up something like 380 watts. But reading my motherboard manual it states a psu of 350 watts or above should be used. This can't mean it draws 350 watts surely, I thought motherboards draw about 30 watts. I think its just taking into account the whole system but I want to be sure. My system is an AMD 64 4000+, 2gb ddr400 (2x1gb), asus a8n-e, 250gb maxtor sata150, ati x800pro, firewire card (for dvcam), cd drive, dvd burner and seperate cd burner and maybe an audigy2 sometime. I'm going to have all of this running on an antec tp2 480. This should be ok shouldn't it?
Last edited by dontknowdontcare : December 16th, 2005 at 05:12 AM. Reason: left something out
dontknowdontcare is offline   Reply With Quote
Old December 16th, 2005, 06:18 AM     #2 (permalink)
Banned
With a dvd burner, two hard drives, 2 1gb Kingston performance dimms, a Sony cd writer,
an ATI 9550 256mb video card, an Audigy 4 Pro, and an Antec 430w TPower supply there
hasn't been any issues here. The extra seen with the 480x will cover the slightly higher draw the newer model AMD will place. But if you are still worried, Antec 550w TPower.
PC TECH250 is offline   Reply With Quote
Old December 16th, 2005, 10:34 AM     #3 (permalink)
Cool
k
That sounds about right, I think 480 should be plenty, its not as if im going to be running everything all at once anyway.
Old December 16th, 2005, 10:38 AM     #4 (permalink)
Megalomaniacal
SoloCamo's Avatar
Send a message via AIM to SoloCamo
what calculator did you use? link?
380w seems to be A LOT from that system... We have a similar system in the house and the calculator we used didn't come nearly close to 380
SoloCamo is offline   Reply With Quote
Old December 16th, 2005, 11:04 AM     #5 (permalink)
elroy's Avatar
A 480 watt Antec would be fine.
Benjamin Franklin
elroy is offline   Reply With Quote
Old December 16th, 2005, 11:09 AM     #6 (permalink)
http://www.jscustompcs.com/power_sup...or.php?cmd=AMD
It comes up as 338 but I added an extra hd and 2 sticks of 1gb ddr (future expansion)
how can i check my psu wattage flyguyspy General Tech Discussion 11 December 6th, 2005 07:45 PM
laptop wattage use? jpiermarini General Tech Discussion 6 July 5th, 2005 02:32 PM
PC wattage and amps andree 33 General Tech Discussion 15 June 10th, 2004 01:33 AM
What wattage PS for my system rangerjoe2001 General Tech Discussion 2 July 1st, 2003 03:55 AM
UPS wattage muno General Tech Discussion 3 September 11th, 2002 09:20 AM
Is It Just Me? (2918)
Wireless Televisions. (10)
Regular Build (6)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
