Building my own computer
Currently Active Users: 2383
Discussions: 200,942, Posts: 2,379,312, Members: 246,305
Old December 26th, 2005, 06:23 PM   Digg it!   #1 (permalink)
This is my first time building a computer. I got all my computer parts for Christmas, but theres a problem...i dont know how to put them together. Im afraid ill crush my AMD athlon64 4000+ when installing the heatsink. should i be? in my mobo manual...it says stuff about switching jumpers before you install video cards... that's when i got lost. I know how to install the parts but the extra stuff i dont know, like stuff having to do with jumpers and that kinda stuff
I need to know which order to put the parts together too. that would be very helpful.
Heres a list of the things that i have:
Asus A8N SLI deluxe
AMD Athlon 64 4000+ CPU
Case
500W PSU
XFX GeForce 6600 Extreme Gamer Edition
1 GB DDR2 RAM
Maxtor 100GB Serial ATA
ANY INFORMATION WOULD BE EXTREMELY HELPFUL
ferby is offline   Reply With Quote
Old December 26th, 2005, 06:33 PM     #2 (permalink)
elroy's Avatar
I would lay the board on a non-conductive surface and install the ram, heatsink/fan, cpu and video card. Now connect the power supply 20 pin and 4 pin connectors and plug it in. Using a screwdriver touch the 2 pins together that would be connected to the on/off switch for about 2 seconds and it should start. This will make sure it is all operable prior to installing in the case. If it starts, unplug it and remove the video card and unhook the power supply from the board. Install the board in the case and go from there.
Benjamin Franklin
elroy is offline   Reply With Quote
Old December 26th, 2005, 06:39 PM     #3 (permalink)
Send a message via MSN to ferret314
okay here goes nothing...
* screw motherboard securely down + any heatshields that came with it.
* install power supply to atx case with all drives as well.
* put power to motherboard. there should be 2 one for cpu and one near the ide cables.
* connect power to your sata hd, also connect the sata to SATA0 or SATA1
*put the cpu chip on the board, it should be a socket 939 which is idiot proof.
* put heat sink on your cpu (make sure it sits flat) push metal clamps down to secure. ( you wont break it)
* insert memory in DIMM 1&2 (referr to motherboard manual to make sure that thats correct to run dual channel)
*if you have on board audio make sure that your Jaud jumped on 5&6 and 9&10 IF you are not using a font aud jack. this jumps it directly to the back of the motherboard. (again, check manual could differ)
* the only other jumper i would think you would need to worry about is if you have more then one cdrom. if you have 1 then throw it on master or cable select. if not, jump one master, and one slave.
*power on, and enter your bios. <delete> or <F10>
* try to detect your drives, if your sata isnt showing check inIDE devices configuration, make sure SATA1&2 are enabled. and disable RAID if your only using one hd, less to worry about.
*save changes and you should post with all drives.
the stage is set, don't forget to breathe.cs
ferret314 is offline   Reply With Quote
Old December 26th, 2005, 07:18 PM     #4 (permalink)
My mobo manual says i have to asign IRQ's to the expansion cards when install them. Im not there yet, but im wondering, What is an IRQ? and how do i assign these "IRQ's" to my expansion cards?
Old December 26th, 2005, 07:49 PM     #5 (permalink)
Abbreviation of interrupt request line, and pronounced I-R-Q. IRQs are hardware lines over which devices can send interrupt signals to the microprocessor. When you add a new device to a PC, you sometimes need to set its IRQ number by setting a DIP switch. This specifies which interrupt line the device may use. IRQ conflicts used to be a common problem when adding expansion boards, but the Plug-and-Play specification has removed this headache in most cases.
Your motherboard should automatically assign this for you.
Old December 26th, 2005, 08:04 PM     #6 (permalink)
(AKA) Nakamura
sweeper2's Avatar
P4 3.0ghz , P4M900-M4 , 450 psu , Sapphire HD 3850 512mb with an Accelero S1 cooler , 2gig pc5300 ddr2, 80gig Deskstar , 16x dvd-rw
Old December 26th, 2005, 08:07 PM     #7 (permalink)
Ultimas w00t! Mastah...
vikeor's Avatar
Send a message via MSN to vikeor
i always put in the ram and CPU first before screwing it into the case....
AMD Opteron 146 2.8ghz 280x10
1GB GEIL ONE S PC3200
DFI LanParty UT NF4 Ultra-D
ATI X1800XT @ 700/800
Enermax Noisetaker 485W
BigWater SE
vikeor is offline   Reply With Quote
Need Help Building Computer! tgroce32 General Tech Discussion 15 October 29th, 2005 12:53 PM
Building a New Computer Nollie General Tech Discussion 34 September 24th, 2005 11:44 AM
Building computer now -FMA General Tech Discussion 20 December 13th, 2004 07:16 PM
Building A Computer UpYourz General Tech Discussion 8 October 24th, 2003 02:12 PM
Building New Computer Shabow General Tech Discussion 13 April 23rd, 2003 07:37 AM
The disrespect of Obama by Russian .. (9)
Making Health Care Worse (150)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
