Results 1 to 4 of 4
    Oct 2004
    Birmingham UK
    522
    antec TP2 EPS12V 550W issue
    The 12V rail on the above PSU is only reading 11.71v on the 12V rail in ITE smart guardian. IS there anyway to adjust the 12v Rail without voiding warranty?
    Opteron 146 @ 2.6Ghz
    Freezer64
    1024mb DDR500 RAM 3-4-4-8
    Leadtek 7800GT 256Mb @ 450/1100 (515/1220 MSF)
    DFI NF4 SLI-D 623-3
    Ultimate Member SeanC's Avatar
    Toronto Canada
    4,800
    Probably not, I think as soon as you open the power supply up, the warranty is voided.
    I'm assuming you're having power problems with the power supply right? I don't "think" 11.71v on the 12v rail is that bad, unless you're having problems.
    Sean
    Ultimate Member elroy's Avatar
    Indiana
    3,774
    11.71 is ok, not perfect but ok.
    Usually + or - 5% is considered reasonable. That would be a range of 11.4 to 12.6 volts. Your voltage readings are not out of line, I get similar readings from cheap power supplies and from a high quality Enermax that I have.
    But if you are still worried about it you can send it to me and I'll test it for a couple years and let you know if it is ok.
    Benjamin Franklin
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,193
    4
    Well, unless you are using a multimeter, the readings are not 100% accurate. Sadly software can't get a perfect reading.
    11.71 is decent, and again it could be better/worse but you won't know for sure unless you physically test it with a multimeter.
    Are you having any actual problems with it, or just nervouse about the readings?
  1. ATX to EPS12V
    By maface in forum General Tech Discussion
    Last Post: December 28th, 2005, 01:54 PM
  2. Neo HE vs TP2
    By Ocrushed in forum General Tech Discussion
    Last Post: December 21st, 2005, 08:23 PM
  3. Antec
    By ObiWan_Kenobi in forum General Tech Discussion
    Last Post: February 12th, 2003, 06:19 PM
