pc wont start
Currently Active Users: 2396
Discussions: 200,970, Posts: 2,379,737, Members: 246,335
Old January 1st, 2006, 04:21 PM   Digg it!   #1 (permalink)
Unhappy
pc wont start
hi hope someone could help me iam having trouble with power to my pc. just yesterday i was using my pc fine i retured to it after leaving on when i did it was like it was in standbye mode so i moved the mouse to try and activate the system and it wouldnt do nothing so the i tryed to turn the thing off but it would not. there is a green light on the front and inside near the battery i have tested the fan with the power supply thats fine and tested the switch wich turns on the pc and thats fine so i dont know whats wrong with the thing. when i pulled out the motherboard power suply and then reconect it the fan starts to spin but then quickly stops it so anyoing please help i getting pd off now
dave959 is offline   Reply With Quote
Old January 1st, 2006, 06:01 PM     #2 (permalink)
hmmm, so you have turned it off now, and it just wont power up?
Don't worry about the CPU fan spinning a little they do that when you plug in an energised or plugged in PSU. ATX motherboards always have current going into them and for an electrical reason not worth going into it will maybe rotate 90,180 degrees on plugging in the PSU.
Anyway, back to the point, what is happening now, the PC won't power on?
Have you tried pulling every device plugged into the PSU except the motherboard and powering up?
Give us a little more insight into the current situation, rather than what happened.
thelonegunman is offline   Reply With Quote
Old January 1st, 2006, 11:09 PM     #3 (permalink)
no i havent been able to turn off the pc the green light is still on on the front of the pc so is that still on or just standby? i have tryed what you said but still the fan wont start iam starting to think that the motherboard has blown or somthing but i dont no that much about these problems i hope you can still help me
Old January 2nd, 2006, 07:46 AM     #4 (permalink)
Hello.
Each computer is different in their designs and 'lights'. It is near impossible for us to tell whether your PC is still on or in standby by only knowing that there is a green light. Some computers change lights in standby and some don't. However, in this case, whether it is still on or in standby doesn't really matter. If it is still on, switch off the power supply and reboot the computer or just press the reboot button. If it is in standby, do it anyway. I think your PC hanged on some program when in standby mode.
I don't think your motherboard has blown, unless your PC was unlucky enough to be struck by a virus attack or a heat wave while in standby. A friend of mine whose PC was struck by a virus attack that blew his motherboard said there was a smell of something melting.
dyknight is offline   Reply With Quote
Old January 2nd, 2006, 08:47 AM     #5 (permalink)
Unhappy
pc wont start
the power button on the fron of the pc should turn the pc off when you hold it in for 8 seconds but mine does not this means that it is already off i think, so lets say thats its off i cant start the thing the fan works, the switch works, i have checked power cables to the power supply, i have tryed all the things that people suggest but still nothing. what do you need to no about my machine to find out whats rong and i will tell you
thanks
Old January 3rd, 2006, 11:44 AM     #6 (permalink)
Thumbs up
new motherboard
i went out today and i brought a new mother board and installed it and now it works fine thanks for your help to all that helped me
OS wont start plowman Applications and Operating Systems 17 December 17th, 2005 01:39 PM
hp wont start rocker35 Technical Support 4 September 10th, 2005 07:58 PM
PC wont start tgroce32 General Tech Discussion 4 November 29th, 2004 12:52 AM
My Pc Wont Start kakoratt Technical Support 5 February 11th, 2004 02:12 PM
Comoputer Wont Start Makavali Technical Support 20 May 4th, 2003 09:10 PM
Is It Just Me? (3044)
Breaking: San Diego ACORN Document .. (10)
Delete an OS (15)
Nvidia GTX 260 problem (7)
Internet Lost (5)
Print spooler problem (16)
Delete an OS (15)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
webcam (0)
upgrade for hp a6101 (0)
