Results 1 to 3 of 3
    Apr 2004
    480
    transfering data
    Is there a way to transfer data on one computers hard drive to another computers hard drive without having to burn the data to a cd or physically moving one hard drive to the second computer ?
    Member LaptopExtreme's Avatar
    Dec 2005
    Los Angeles, CA
    318
    Yes, you can share the one computer's HD buy networking together, or open the unit , remove the HD and install it as a secondary HD. The transfers using the 2nd method would be the fastest. But if you dont know how to do either one, burning a CD would be best. You can also use a thumb drive, if you have one.
    Senior Member bwcc's Avatar
    Nov 2001
    Central KS
    847
    They do make USB, Parallel, and Serial 'smartlink' cables that come with software to link to systems together. If both machines are on a network, that would be one way - as laptopextreme said. If not, but both system have a network card, you can use a cross-over cable to connect the two via a network.
    Im against picketing, but I dont know how to show it.
  1. Replies: 5
    Last Post: March 14th, 2013, 01:17 PM
  2. Transfering Data from office to store
    By tboy in forum Networking and Internet
    Last Post: March 21st, 2004, 05:58 PM
  3. Transfering Database
    By SplitCo in forum Webmastering and Programming
    Last Post: August 6th, 2003, 12:14 PM
  4. transfering data from old hdd to new hdd
    By tpik in forum Storage Related
    Last Post: October 29th, 2002, 02:49 AM
