No Signal on monitor
Currently Active Users: 1439
Discussions: 200,507, Posts: 2,374,395, Members: 245,831
Old January 11th, 2006, 09:33 PM   Digg it!   #1 (permalink)
Got a freebie trying to see if it is any good. When i turn it on fans come on the hard drive spins but nothing come up on monitor just says no signal. Here is the info on the computer
Microstar mother board ms-6390
amd Athelon xp 1500
graphics card GeForce4 mx 400
I put a hard drive in out of a machine that is working and I still get the same thing no signal.
cannot swith graphics card because everything I have will not fit.
Thanks for any advice
madgvr4 is offline   Reply With Quote
Old January 11th, 2006, 09:36 PM     #2 (permalink)
NightRise420's Avatar
Send a message via AIM to NightRise420
Does the motherboard beep? If u just put the computer together, ur CPU might not be fully inserted in the socket.
Live Fast, Die Young, Dont Forget, Dont Regret
NightRise420 is offline   Reply With Quote
Old January 11th, 2006, 09:40 PM     #3 (permalink)
no beeps nothing just fans. It looks like a better set up then what i currently have just need a little advice to try and get it going
Old January 11th, 2006, 09:53 PM     #4 (permalink)
does that motherboard have onboard video? If it does, try using onboard video first. cuz it'll prioritize onboard rather than the card u have. If the onboard doesn't work, try using another monitor. If the monitor doesnt work, all i can say is the motherboard is dead.
Old January 11th, 2006, 10:02 PM     #5 (permalink)
i've allready done all of that nothing, Im not an expert by any means I was hoping it might be something else. ohwell I dont know enough about motherboards but it does have lots of jumpers could this be a problem.
Old January 11th, 2006, 10:10 PM     #6 (permalink)
well....whats ur cpu? what fsb?
Old January 11th, 2006, 10:19 PM     #7 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
quick and easy...
pull the board out of the case set it on a phone book or something none conductive leavinf the power supply connected you'll need to connect the power buttons as well{always forget to mention that}. leave in only the cpu/hs/fan one stick of memory and a vid card if there is no onboard unplug the power supply from the wall and clear the cmos using the jumpers if there are some if not pull the battery out
replace the battery and give it a try, this will rule out grounding in the case
Linus Torvalds
RicheemxX is offline   Reply With Quote
Old January 11th, 2006, 10:25 PM     #8 (permalink)
i just got the computer and it was like this i took the cpu out and it is an
amd athelon 1500 333 MHZ, 256 L2 cach, front side bus 266 MHZ
mother board is micro-star ms-6390
site says it takes 184-ddr dimm so i bought a new 512 stick tried both slots
graphics is a geforce mx440
tried on board also
psu - says L&C model LC-300atx
and i have to ask what is fsb
ram is nanya 512mb ddr333
Old January 11th, 2006, 10:27 PM     #9 (permalink)
looking at other cases like this how do you reset the cmos
Old January 11th, 2006, 10:40 PM     #10 (permalink)
fsb is front side bus as u stated of 266Mhz. You may have to set ur jumper on ur motherboard to 266Mhz FSB. Not sure but ur motherboard might have jumpers for different FSB settings like 266, 533, 800 FSB.
Monitor is not getting a signal from video card msoneji Technical Support 6 May 27th, 2009 09:13 PM
Video Monitor: No Signal... Master Chief General Tech Discussion 12 October 5th, 2005 10:10 PM
no signal to monitor nutkase General Tech Discussion 6 July 8th, 2004 06:38 PM
No Signal on Monitor Woogly Master Graphics Cards and Displays 3 February 9th, 2004 04:16 AM
Gateway Monitor gives no signal message Chuckiechan General Tech Discussion 3 June 15th, 2003 04:51 PM
Is It Just Me? (1635)
Review My Build (5)
Assosiations (21496)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
