Crackling sound coming from PSU
Currently Active Users: 1457
Discussions: 204,499, Posts: 2,419,348, Members: 249,921
Old January 23rd, 2006, 03:17 PM     #41 (permalink)
SpaceSquad's Avatar
Send a message via MSN to SpaceSquad
Originally Posted by just_a_nobody
If your power supply came with the case new, then it is a cheap one, and it should not be trusted.
It's made by a very high quality manufacturer...it is a very good psu
it does, however, seem to be malfunctioning.
-Space
SpaceSquad is offline   Reply With Quote
Old January 23rd, 2006, 04:00 PM     #42 (permalink)
Training for Bankai
JPMiller's Avatar
That is a foolish assumption...
NOT all "included" PSU's are bad at all...
Antec and Thermaltake are the obvious exceptions, as well as a few others...
Try not to dispense advice in absolutes... there are few out there... and usually several people that will dispute them.
Old January 23rd, 2006, 04:06 PM     #43 (permalink)
just_a_nobody's Avatar
I have seen cases costing $35 with antec power supplies installed, are you telling me that that power supply is not a cheap one? You're right, those two brands, that you mention, and enermax are my preferred brands, antec is one of the best, but the ones that come with cases, as a package, I would hold as suspect, and would not trust any of them in my systems.
just_a_nobody is offline   Reply With Quote
Old January 23rd, 2006, 07:47 PM     #44 (permalink)
Coolzer's Avatar
Should i send my antec back under warrenty......The thing is that if i do and they find nothing wrong with it then they will charge me a minimum of 45 dollars for their time!
Coolzer is offline   Reply With Quote
Old January 23rd, 2006, 08:10 PM     #45 (permalink)
Swine flu stopper
Mickwish's Avatar
If you have a muiltimeter you can check the voltages being outputted by the suspect PSU. If they are below the specs Antec has provided they will replace it. If you are not handy with a multimeter maybe you can find a neighbourly electrician who is? The specs are quite clearly written in the PSU manual, or can be gotten from the Antec site as well.
I have an Antec PSU tester which will allow you test PSU's. Very handy little gadget; many PC stores have one. If you have a small PC repair store near, maybe the tech there will check it for you before you send it back to antec?
Whilst Antec are a good makes of PSU's, they can have problems. I have a Minuet II case that the PSU died in in less than 6 months. Antec are currently replacing it, via my local PC shop, under warranty.
Cheers
Mick
edit: This explains how to do this.
I don't like sigs on forums like this.
Mickwish is offline   Reply With Quote
Old January 23rd, 2006, 08:46 PM     #46 (permalink)
Coolzer's Avatar
ok will do mick, thanks!
I do have a multimeter and are currently halfway through an electronics course at highschool so this should work out ok...
Old January 27th, 2006, 04:11 AM     #47 (permalink)
Coolzer's Avatar
Antec PSU's are great when they come with cases......Yes you are right that some cases come with generic PSU's..... but this is not always...such as in my case...
Mick....
I tested with multimeter and all power rails are exact exept the 12v rail.. It read's 10.89 instead 12v....What does this mean
Old January 27th, 2006, 05:36 AM     #48 (permalink)
Training for Bankai
JPMiller's Avatar
if your getting a reading that low from a multimeter, then that is way below spec, and most likely your problem...
the +12V rail is really the most important on current systems and if thats the one thats low, that would cause all kinds of issues
Old January 27th, 2006, 06:16 AM     #49 (permalink)
Coolzer's Avatar
ok it is under warrenty, i'll send it back.
Old January 27th, 2006, 06:27 AM     #50 (permalink)
Coolzer's Avatar
Thakyou for all your replies
Sound Coming Out From The CPU magicz69 Technical Support 9 February 22nd, 2006 05:25 PM
Crackling sound while playin Doom3... Butanoicacid General Gaming Discussion 13 August 4th, 2004 02:52 PM
popping sound coming from speakers CyberGhost Multimedia and Audio 2 June 15th, 2004 08:15 PM
MSI DVD sound crackling stamenkd Multimedia and Audio 3 December 3rd, 2003 11:33 PM
Crackling sound A7N8X Eryk Motherboards 3 August 7th, 2003 10:35 PM
Is It Just Me? (1578)
CBO: Obama's health care plan cuts .. (100)
USB not recognised..... (16)
Do you use "self check-out&quo.. (10)
would this build be enough for WOW? (14)
Recent Problem (15)
Need some suggestions on building a.. (26)
[ F@H Chat] 03/07/10 New Month New.. (89)
Motherboard the culprit? (6)
Suggestions? (6)
Can't Rename Files (11)
Hard drive full = slower computer? .. (6)
Want a new power supply for my Dell.. (35)
Windows XP Pro Error log (8)
Sim Societies won't launch (0)
Help! Cisco Switch port (interface) f.. (0)
[ F@H Chat] 03/07/10 New Month New T.. (89)
Need some suggestions on building a g.. (26)
burner not burning. (3)
YOUR BEST TRICK OR TIP FOR YOUR COMPU.. (20)
HTML (2)
Hard drive full = slower computer? Is.. (6)
Reading Raw data off an SD (MMC) card (8)
Recent Problem (15)
Can i upgrade my gateway nv5448u grap.. (1)
Drive 0 not found: Serial ATA, Sata-0 (9)
i need to find my DNS server IP addre.. (21)
HP Pavillion Laptop ze4220 won't turn.. (15)
Lexmark Printer Prestige pro805 (0)
E:\Pictures is not accessible. the d.. (4)
Replacement hard drive for Dell 600M (18)
toshiba l300-20d upgrade (0)
AE's Windows Troubleshooting Guide (24)
Audio skips when I play a cd or dvd o.. (0)
Want a new power supply for my Dell. (35)
