Crackling sound coming from PSU
Currently Active Users: 2668
Discussions: 200,965, Posts: 2,379,623, Members: 246,332
Old January 18th, 2006, 12:14 AM   Digg it!   #1 (permalink)
Coolzer's Avatar
Hi guys,
I have an Antec 350 watt PSU and when i load any game there is a crackling sound comeing from it. As soon as i exit the game the sound diappears...... This started happening when i installed my new 6600GT graphics card. I am thinking that maybe i am drawing to much power from the PSU and maybe i need to buy another PSU 400watt to 450watt.....
Please help......
Coolzer is offline   Reply With Quote
Old January 18th, 2006, 12:20 AM     #2 (permalink)
Swine flu stopper
Mickwish's Avatar
Back away from the PC real slow, and call the Fire Dept!
only joking....
Sounds like it's trying to draw power that's not there. Have you got a extra power cable for the vid card? Is it plugged in??
That Antec should provide good power across 12V and 5V rails, but it may, as you think, not be enough to power all devices under load. So, if you'vbe powered the vid card correctrly, and it still does it, a new PSU that has more grunt, and good 5V and 15V outputs, should help.
What else is in the system (eg your system specs)? Might help work out what size PSU would be best.
Cheers
Mick
I don't like sigs on forums like this.
Mickwish is offline   Reply With Quote
Old January 18th, 2006, 12:23 AM     #3 (permalink)
ph34r t3h g04t
Whir's Avatar
Drawing too much power or not, a power supply should not crackle. That's a defective unit. Return it if possible and get it replaced.
Old January 18th, 2006, 12:27 AM     #4 (permalink)
Swine flu stopper
Mickwish's Avatar
I wonder if the sound is from the PSU or the system, myself.. If there was arcing going on inside the PSU, you'd expect the PC to lock up.
But, might be a possible faulty unit. In that case, Fire Dept on standby would be a good idea, actually!
Cheers
Mick
Old January 18th, 2006, 12:36 AM     #5 (permalink)
ph34r t3h g04t
Whir's Avatar
When I first got my Enermax 350W, it made my Radeon squeal. I put an old 230W Sparkle in and it was fine.
But crackling, yeah, I dunno. I'd be all about getting it replaced.
Old January 18th, 2006, 12:44 AM     #6 (permalink)
Coolzer's Avatar
It came with an antec case. Anyways....my card did not come with a power cable......does it need one?
Xpertvision Geforce 6600GT 128mb
Old January 18th, 2006, 12:54 AM     #7 (permalink)
SpaceSquad's Avatar
Send a message via MSN to SpaceSquad
Apparently, as seen in another thread, the PCI-Express 6600GTs have no ecternal power connector, only the AGP ones.
And yea, I'd replace that thing
-Space
SpaceSquad is offline   Reply With Quote
Old January 18th, 2006, 12:56 AM     #8 (permalink)
ph34r t3h g04t
Whir's Avatar
The 6600GT does, in fact, not have an external power cable. Apparently the PCI-Express bus provides enough extra or something.
Old January 18th, 2006, 12:58 AM     #9 (permalink)
Coolzer's Avatar
i am thinking of buying a new PSU.....
this one
https://www.techbuy.com.au/products/...wer_Supply.asp
EDIT EDIT EDIT
or this one
https://www.techbuy.com.au/products/...play_Meter.asp
I might use the Antec in another computer....(older and rus on less power)
Old January 18th, 2006, 01:26 AM     #10 (permalink)
Swine flu stopper
Mickwish's Avatar
CoolerMaster PSU's have had both good and bad reviews I've seen. I think it depends how far you push your hardware, really. If yoiu aren't gonna push a serious overclock on CPU/RAM/vid card, then a CoolerMaster PSU should be fine IMO.
Not a bad price, either...
Cheers
Mick
Sound Coming Out From The CPU magicz69 Technical Support 9 February 22nd, 2006 06:25 PM
Crackling sound while playin Doom3... Butanoicacid General Gaming Discussion 13 August 4th, 2004 03:52 PM
popping sound coming from speakers CyberGhost Multimedia and Audio 2 June 15th, 2004 09:15 PM
MSI DVD sound crackling stamenkd Multimedia and Audio 3 December 4th, 2003 12:33 AM
Crackling sound A7N8X Eryk Motherboards 3 August 7th, 2003 11:35 PM
Forty-six years ago today (6)
Is It Just Me? (3006)
Internet Lost (5)
windows vista security holes (14)
Open With ..... Win7 (2)
Internet Lost (5)
Help getting around port 80 for camer.. (3)
virus blocking exe. files (1)
Nvidia GTX 260 problem (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
