HELP! My first computer build advice!
Currently Active Users: 2128
Discussions: 200,511, Posts: 2,374,426, Members: 245,836
Old January 18th, 2006, 04:47 PM   Digg it!   #1 (permalink)
Fruit&Veg's Avatar
Send a message via MSN to Fruit&Veg
Im currently planning my first build for a computer, and am taking quite a big risk. the only thing ive ever done to my current computer was install RAM. and i had problems with that
So yes, heres all the parts ive selected so far im hoping you guys can confirm that they would all work together and are the best choices for the price.
Im from England, UK. So my budget is £500.
And im using sites like;
[LINK="http://www.ebuyer.com/customer/home/"]http://www.ebuyer.com/customer/home/[/LINK]
and
[LINK="www.dabs.com"]www.dabs.com[/LINK]
So heres my build!
[LINK="http://www.dabs.com/productview.aspx?Quicklinx=3SYF"]Motherboard with Built in LAN and Sound[/LINK] - ASRock S939 Athlon ULi m1695 ATX A L - £48.04
[LINK="http://www.dabs.com/productview.aspx?Quicklinx=3P7B"]Processor[/LINK] - AMD Athlon 64 3200+ Socket 939 512KB Inc Fan - £113.01
[LINK="http://www.ebuyer.com/customer/products/index.html?rb=15313176574&action=c2hvd19wcm9kdWN0X 3Jldmlld3M=&product_uid=81344"]Graphics Card[/LINK] - PNY Verto GeForce 6 6600GT AGP8x 128MB GDDR3 - £100
[LINK="http://www.dabs.com/productview.aspx?Quicklinx=3NWS"]Hard-drive[/LINK] - Maxtor DiamondMax Plus10 300Gb U133 - £82.22
[LINK="http://www.dabs.com/productview.aspx?Quicklinx=2LGM"]Memory (RAM) x2[/LINK] - Crucial 512MB 184Pin DIMM PC3200 DDR RAM Non-Parity CL3 - £27.61
[LINK="http://www.overclockers.co.uk/acatalog/Antec_Cases.html"]Case and Powersupply (reconsidering this one)[/LINK] - Antec Black Quiet Mini Tower Case - 350W - £46.94
[LINK="http://www.overclockers.co.uk/acatalog/Online_Catalogue_Operating_Systems_20.html"]Windows... [/LINK] - Microsoft Windows XP Home Edition with Service Pack 2 - £62.92
[LINK="http://www.dabs.com/productview.aspx?Quicklinx=33S3"]CD Drive[/LINK] - Sony CD-RW/DVD 52x32x52x16x - £23.34
This build is currently at something like £586
Like i said my major issue with these components is compatability. im also wondering if i need some cooling stuff. any tips or recommended changes you guys can give will be brilliant. Cheers
New Computer:
MSI K8N Neo4 nForce4
AMD 64 3200+ Processor @ 2.1ghz
1gb G.Skill Dual Channel DDR Ram
GeForce 6800 GS 256MB
FSP Sparkle ATX 400w
Fruit&Veg is offline   Reply With Quote
Old January 18th, 2006, 05:36 PM     #2 (permalink)
i dont know alot about computers myself but i think the cooling should be in the psu in the case? or i think u've sorted that out. what is the main use of the pc going to be? gaming? music?
im sure others will fill in the gaps for you! im building/modding my own pc at the moment and im having the same worries about compatability.
niall is offline   Reply With Quote
Old January 18th, 2006, 05:53 PM     #3 (permalink)
Fruit&Veg's Avatar
Well its mainly going to be a gaming rig to replace my current
1.4Ghz AMD Athlon
512mb Ram
GeForce3 Ti200 64mb
80GB HD
I mainly want to play Half Life 2 with better results.
Well its good to hear im not the only one worried about compatability, hopefully ill get some good replies and be able to go ahead with buying.
Old January 18th, 2006, 06:08 PM     #4 (permalink)
I can't beleive Windows cost more than the video card.
FlyinHawaiian is offline   Reply With Quote
Old January 18th, 2006, 06:40 PM     #5 (permalink)
Super F@D Folder
I'd strongly recommend going with a sata harddrive, a motherboard using an nforce4 chipset of any time (regular, ultra, or sli, your choice) and going with the pci-express graphics card. Also, maybe a nicer psu!! Other than that, everything else looks good so far (but i looked quick so I'd wait for someone who looks over it a little better before you order!)
Old January 18th, 2006, 07:18 PM     #6 (permalink)
Send a message via AIM to RamonGTP Send a message via MSN to RamonGTP Send a message via Yahoo to RamonGTP
Yeah, i'm definatly not feeling that motherboard/chipset
RamonGTP is offline   Reply With Quote
Old January 18th, 2006, 07:22 PM     #7 (permalink)
i going to go for this mother board http://www.buy4now.ie/galaxy-compute...e=&searchtype=
if that helps ya fruit&veg
Old January 18th, 2006, 08:58 PM     #8 (permalink)
Fruit&Veg's Avatar
oh really? i was thinking thats the most sure thing on that list tbh.
What about this one vvv
http://www.dabs.com/productview.aspx...0&v=2#infoarea
Its much more expensive tho...
Old January 18th, 2006, 09:02 PM     #9 (permalink)
that looks sweet, and i say never cut corners on the mother board, im willing to fork out 200 euro on my one, because i really dont want to have to replace it for a good 5or 6 years
New build + scanner advice Bill in SD, CA General Tech Discussion 3 March 8th, 2005 03:56 PM
New build advice please. jerrygarcia General Tech Discussion 8 October 18th, 2003 02:25 PM
Advice for a 1st time build starrboy General Tech Discussion 11 August 2nd, 2002 08:35 PM
Trying to build my first PC, looking for some advice. Firebrand General Tech Discussion 5 July 20th, 2002 03:19 AM
Help me with some advice....Which is better..build a comp or just sell the parts? John Prophet ResellerRatings Homepage Deals 6 April 26th, 2002 01:56 AM
Is It Just Me? (1638)
windows 7 retail and rtm (5)
HELP!!! What do you think of this s.. (18)
Review My Build (6)
Assosiations (21499)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
HELP!!! What do you think of this sys.. (18)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
