Blu-Ray Question
Currently Active Users: 1476
Discussions: 200,930, Posts: 2,379,155, Members: 246,297
Old January 24th, 2006, 04:54 PM   Digg it!   #1 (permalink)
Send a message via AIM to JimRune Send a message via MSN to JimRune
Blu-Ray Question
Someone posted this on the GameSpot forums and I'm wondering if it holds any water:
very optical drive starts with CLV or constant linear velocity drives and then progresses to CAV or constant angular velocity.
CLV is good at reading data in adjacent sectors, however when data is scattered all over the disk (as is the case with games) there is a whole lot of slowdown due to poor seek times. CAV does not have this problem.
Both the sega CD and the PSP had CLV drives, and they have both demonstrated poor loading times. The good news is, PS3 games won't be on blu ray. They will be on DVD, just like xbox 360 games. They will not be on blu ray because of the poor seek times from the CLV blu ray drive.
This is a +10 Post of Awesomeness. It is impervious to rebuttal, factual inaccuracies, and logical inconsistencies. Opinions expressed are 100% truth.
JimRune is offline   Reply With Quote
Old January 25th, 2006, 09:00 AM     #2 (permalink)
Caveat Emptor
Rootstonian's Avatar
Good. Nothing ruins a game's pace more than those stupid load pauses.
God of War on the PS2 loads fast, saves fast and reloads fast. Prince of Persia, Two Thrones on the PS2 is the complete opposite, IMO.
Old January 26th, 2006, 01:42 AM     #3 (permalink)
micfau1091's Avatar
Send a message via AIM to micfau1091 Send a message via Yahoo to micfau1091
System specs by Sony show that that their drive is capable of reading CDs, DVDs, and blu-ray discs...so really, its up to the game dev on which to use..
As for the seek times, the only thing I can think of, is that because the BluRay disc holds sooo much more than the DVD, content maybe more hard to find just because the fact that you have to sort through much more content...other than that...there shouldn't be any difference in seektimes as the read times on the bluray and dvd aren't that big of a difference.
Bottom line - game devs are going with the BluRay because they can put over 40gb more content than if they were to use a dual layer dvd...which means either very very long games at the same quality of the content on dvds, or high quality content at the same game length as the dvds...their choice.
Gaming: AMD64 3K+, X1800GTO 256, 120gb7200
Personal/Living Room Gaming: (laptop)AMD64 3K+, 9700pro, 60gb5400
micfau1091 is offline   Reply With Quote
Old January 26th, 2006, 11:30 AM     #4 (permalink)
its the lasers footprint that is smaller which allows for more storage capasity on optical media disc's..
however there's nothing to say that blu-ray is going to be backwards to current media standards and the dye the media uses when you burn a disc whether it be cd or dvd..
redacidman is offline   Reply With Quote
Old January 26th, 2006, 12:07 PM     #5 (permalink)
erhan28's Avatar
Send a message via MSN to erhan28 Send a message via Yahoo to erhan28
yes load time is a worry but big selling games like GTA needs the space for the map.
It would be nice to have GTA for ps3 in blueray that get the whole city 3x the size of san andreas. It also would be nice to have more cars and buildings to go into.
Of coarse there will be load time and i for one can wait. I hope the new GTA series from rockstar will be better and bigger.
MSI K8N Neo4 Platinum / A64X2 4800+ Toledo(Stock)
7900GTX 698mhz / 2GB Corsairs XMS PRO Dual
Hitachi SATA II (2x 250GB, 1x 500GB)
ASUS G1
erhan28 is offline   Reply With Quote
Trend to Blu-Ray rex028 General Tech Discussion 4 January 8th, 2005 07:59 PM
Blu-Ray more superior to DVD Friedchicken100 Multimedia and Audio 4 December 16th, 2004 03:46 PM
X-ray question gerald_weigel General Tech Discussion 1 November 10th, 2004 01:32 PM
Ozone/UV ray question Urban_Squrill IMO Community 4 November 14th, 2003 01:04 AM
X-Ray And Laptops? e980238 General Tech Discussion 5 June 24th, 2003 05:50 PM
Is It Just Me? (2870)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
