broken sound?  | |
February 2nd, 2006, 09:58 PM
Ok, heres the story, yesterday i bought a new case and was transfering all my shit over and apparently in the processes my onboard sound stopped working. Correction, half stopped working
On the restart up after relizing the only sound i was getting was what sounded like blowing wind at random times, the sound worked perfectly, and i thought it was fixed
now upon a few restarts later it is still broken, I cant describe the sound other than random spurts of noise that sound if wind is blowing.
can anyone tell me how or why this is happening and how to fix?
MOBO: http://www.asrock.com/product/939Dual-SATA2.htm |
February 2nd, 2006, 10:30 PM
sounds too simple but double check that the speakers are plugged in all the way...that sounds alot like what happens when it is halfway out
see what happens when you twist the cable around sometimes when they start to go bad you need to get them in the right position for proper connection
Hey who turned sigs on?
February 3rd, 2006, 12:11 AM
still doesnt work :\ i dunno what to do, iv already reinstalled drivers :[ |
February 3rd, 2006, 01:23 PM
How about the volume settings on the computer and applications?
__________________ Mac Mini—2Ghz—2GB RAM—Snow Leopard
EEE 1000H—1.6Ghz—1GB RAM—XP |
February 3rd, 2006, 02:58 PM
Nothing causing interference to the speakers or the wires?
AMD Phenom Q9500 Quad-Core 2.2ghz / Asus M3A78-EMH HDMI / 4GB PC667 RAM / 320GB SATA II
February 3rd, 2006, 04:31 PM
what would be interfering with my wires on my headset?
what should i look for?
and yes all meh sound is unmuted so everything should turn on, im not getting sound from games, music, or just plain starting up windows.... nothin... |
February 3rd, 2006, 05:04 PM
It would be a good idea to try another set of speakers or headphones to rule out the speakers currently connected as the problem. I would also start looking for another sound card. Decent sound cards can be had for little investment. |
February 3rd, 2006, 09:18 PM
| | Human voltmeter
Are you using front audio ports or the rears?
If you're using the rears, double check that you've got shorting jumpers to connect BackOut-L to AudioOut-L and BackOut-R to AudioOut-R.
If you're using front connectors, double check that they're going to the correct pins (AudioOut-L, AudioOut-R, and Ground) |
February 3rd, 2006, 11:45 PM
i just decided to buy a sound blaster live! for 30 bucks, simpler solution and I have been wanting a sound card n e ways so i guess its all good now... |
