March 20th, 2002, 06:54 PM
ok i have this program called filefreedom that pops up when windows boots. How can i get rid of it? it will not show in add remove programs , and the only way to close it is to use alt. ctrl delete. but i think it is still running in the back ground. my guess is i need to format to get rid of it, but i wanna check with ppl here before i do. and one more thing, is this program spyware? thakns for your time and help jigga. |
March 20th, 2002, 07:09 PM
Look in the startup folder for something by that name.
Depending on your OS the startup folder can be different places so let me know if you can't find the folder.
Easiest way is to search your C drive for 'startup' this will show all of the startup folders. 9x generally has only 1 but win2k has 3.
good luck,
cstierhoff
Out Playing in Traffic
March 20th, 2002, 07:12 PM
| | Real gangstas sip on Yacc
jiggawho?
hehe seriously though folks
Go to Start -> Run and type msconfig
Click on the startup tab and look for it. If you find it un-check it.
Also head here http://www.lavasoftusa.com/downloads.html
and pick up adaware. It will remove any spyware you have
Jkrohn
Signatures blow hard
March 20th, 2002, 07:21 PM
thanks guys i did that jkrohn and un checked it , but will that dlelete it from my system? or does it matter. btw i use xp pro.
thanks, jigga |
March 20th, 2002, 07:24 PM
That does not delete it, only stops it from starting up.
I would reccomend getting the adaware and running it quick. May get rid of it.
Is this the program? http://download.cnet.com/downloads/0...20-100-8751305
From what I'm reading this program is a bear to get rid of. I'll kepp looking for a solution
Jkrohn |
March 20th, 2002, 07:43 PM
yeah that is the program, i bet my roomate was doing something and d/l by mistake, he doesn't know how to use a computer he just clicks stuff a hundred times to close things out. i'm glad he is gettin a computer next week  . any way thank you and i will run that program.
