Using USB 2.0 IDE Adapter on external 'internal' drive - HELP!!!
Currently Active Users: 1077
Discussions: 204,507, Posts: 2,419,425, Members: 249,924
Old February 22nd, 2006, 09:08 PM   Digg it!   #1 (permalink)
Hi
I have just bought a 200GB IDE internal HD to use for backup, and have also bought a USB 2.0 to IDE adapter to use the HD as a pseudo external drive. The idea was that when I have fileld up this HD, I can buy another cheap IDE drive without having to fork out heaps for a proper external drive.
I'm having a little trouble with the setup though.
The adapter doesn't need a driver in Win XP, which I am using. When I plugged everything in, the computer detected new hardware, but I can't seem to locate the HD in My Computer anywhere.
What is the typical procedure for setting up this kind of poor mans external drive? Do I need to go into the bios at all to detect the HD when using it via USB?
Also, when powering down the computer, I suspect that the HD will keep running since it's connected to an external power supply. Is it safe to just turn the HD power off at the wall after the computer has shut down, or is there another way of doing it to protect the HD?
Thanks!
Shaun
I'm looking for a male vocalist to work with. Go to http://people.aapt.net.au/celebritymusic/s...ikingsmith.html to email me
celebritymusic is offline   Reply With Quote
Old February 23rd, 2006, 01:30 AM     #2 (permalink)
jrsweger's Avatar
If you go to MY COMPUTER and right click then click on MANAGE, does the drive show up? You will likely have to partition and format the drive for it to work as well as be recognized properly. It is also possible that the drive letter assigned is a duplicate. If that is the case you can change the assigned drive letter.
jrsweger is offline   Reply With Quote
Old February 23rd, 2006, 02:02 AM     #3 (permalink)
OK
The pc I'm testing it on now has one OS hard drive, and two ther drivs set up in a raid config. i've plugged this 4th HD into a spare power and IDE cable, set it to slave, and went into BIOS after booting up.
There is no sign of the drive anywhere in bios.
What am I doing wrong?
Shaun
ps -I've tried attaching the HD internally, because I thought that would be an easier way to partition it before I use it as an external drive attached to the USB-IDE converter.
Old February 23rd, 2006, 02:08 AM     #4 (permalink)
jrsweger's Avatar
Brand of the drive? If you put the drive onto the same IDE cable as the other existing drive, did you change the drive select jumper of the existing drive? (WD drives are very particular about this) Most WD drives to be a stand alone master require no jumpers but when you add a slave you need to install a jumper to either the CS or MA pins.
Old February 23rd, 2006, 03:22 AM     #5 (permalink)
Training for Bankai
JPMiller's Avatar
Before you can use it as an external, you will have to slave it internally and use either the manufacturer's tools to set it up as an extra storage drive... or format it and partition it with the windows utility...
Old February 23rd, 2006, 03:30 AM     #6 (permalink)
Hi
Cool - that's what I'm doinf now - it's formatting as we speak. Hopefully Windows will recognise it externally once it has been formatted.
Shaun
Old February 23rd, 2006, 03:51 AM     #7 (permalink)
Thats the way it always works for me
cysus is offline   Reply With Quote
Old February 24th, 2006, 12:15 AM     #8 (permalink)
Banned
ck42866's Avatar
did it work?
ck42866 is offline   Reply With Quote
Old February 24th, 2006, 12:20 AM     #9 (permalink)
Hi
Yeah - it worked on one PC, and I'll try the other PC tomorrow :-)
Thansk for all your help guys!!!
Shaun
Internal IDE HD as External. aje Storage Related 7 May 7th, 2006 12:46 AM
Internal CD to external CD USB Sixpac_XP Storage Related 2 October 12th, 2003 04:57 PM
External USB 2.0 Case for 3.5''/5.25'' IDE Drives $42.50 Richard Cranium Technical Support 0 October 14th, 2002 11:31 AM
32x12x40x Internal IDE CD-RW Drive $59.95 Richard Cranium ResellerRatings Homepage Deals 3 May 30th, 2002 10:12 PM
HP 9510i 12x8x32x CD-RW Internal IDE Drive with Software $70 Fisheagle ResellerRatings Homepage Deals 0 December 15th, 2001 02:30 AM
Is It Just Me? (1595)
USB not recognised..... (16)
What Happens If You Have Health Ins.. (7)
would this build be enough for WOW? (14)
Recent Problem (15)
Need some suggestions on building a.. (29)
[ F@H Chat] 03/07/10 New Month New.. (89)
Motherboard the culprit? (7)
Can't Rename Files (11)
Suggestions? (6)
Windows XP Pro Error log (9)
Hard drive full = slower computer? .. (6)
Want a new power supply for my Dell.. (35)
YOUR BEST TRICK OR TIP FOR YOUR COMPU.. (22)
169 ip address question (4)
Help! Cisco Switch port (interface) f.. (1)
First time builder (0)
Need some suggestions on building a g.. (29)
About to install a new heatsink and I.. (1)
SSH Tunnel Or OpenVPN? (0)
burner not burning. (4)
Sim Societies won't launch (0)
[ F@H Chat] 03/07/10 New Month New T.. (89)
HTML (2)
Hard drive full = slower computer? Is.. (6)
Reading Raw data off an SD (MMC) card (8)
Recent Problem (15)
Can i upgrade my gateway nv5448u grap.. (1)
Drive 0 not found: Serial ATA, Sata-0 (9)
i need to find my DNS server IP addre.. (21)
HP Pavillion Laptop ze4220 won't turn.. (15)
Lexmark Printer Prestige pro805 (0)
E:\Pictures is not accessible. the d.. (4)
Replacement hard drive for Dell 600M (18)
toshiba l300-20d upgrade (0)
