Hi I have seen these around and you guys have really great pc's from what I have seen. So if nobody minds could you rate mine tell me what you would upgrade or what not and what games I won't be able to play, I will post this all from Everest ok here goes bare with me...... (be gentle lol but honest)
Computer:
Operating System Microsoft Windows XP Home Edition
OS Service Pack Service Pack 2
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name HOME-09D1728425
User Name Sasuke
Motherboard:
CPU Type Intel Pentium 4 530, 3000 MHz (15 x 200)
Motherboard Name Asus P5GD2-X (3 PCI, 3 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
Motherboard Chipset Intel Grantsdale i915P
System Memory 1536 MB (DDR2 SDRAM)
BIOS Type AMI (11/29/05)
Communication Port Communications Port (COM1)
Communication Port ECP Printer Port (LPT1)
Display:
Video Adapter NVIDIA GeForce 6600 (256 MB)
3D Accelerator nVIDIA GeForce 6600 PCI-E
Multimedia:
Audio Adapter Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Storage:
IDE Controller Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
IDE Controller Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
Disk Drive WDC WD800JD-00LUA0 (74 GB, IDE)
Optical Drive AOPEN DUW1616/ARR (DVD+R9:4x, DVD+RW:16x/4x, DVD-RW:16x/4x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW)
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 76308 MB (63130 MB free)
Input:
Keyboard HID Keyboard Device
Mouse HID-compliant mouse
Network:
Network Adapter Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller
Overclock
CPU Properties:
CPU Alias Prescott
CPU Stepping E0
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 3.00GHz
CPUID Revision 00000F41h
CPU Speed:
CPU Clock 3012.47 MHz (original: 3000 MHz)
CPU Multiplier 15.0x
CPU FSB 200.83 MHz (original: 200 MHz)
Memory Bus 200.83 MHz
CPU Cache:
L1 Trace Cache 12K Instructions
L1 Data Cache 16 KB
L2 Cache 1 MB (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties:
Motherboard ID 63-0501-000010-00101111-112905-I915$A0319001_BIOS DATE: 11/29/05 16:53:37 VER: 08.00.10
Chipset Properties:
Memory Timings 3-3-3-8 (CL-RCD-RP-RAS)
SPD Memory Modules:
DIMM1: Xerox MALABS 1 GB DDR2-533 DDR2 SDRAM (5.0-4-4-11 @ 266 MHz) (4.0-4-4-11 @ 266 MHz) (3.0-3-3-8 @ 200 MHz)
DIMM2: Samsung M3 78T6553BG0-CCC 512 MB DDR2-400 DDR2 SDRAM (5.0-3-3-8 @ 200 MHz) (4.0-3-3-8 @ 200 MHz) (3.0-3-3-8 @ 200 MHz)
Graphics Processor Properties:
Video Adapter nVIDIA GeForce 6600 PCI-E
GPU Code Name NV43 (PCI Express x16 10DE / 0141, Rev A2)
GPU Clock 299 MHz
Memory Clock 250 MHz
Sensor
Sensor Properties:
Sensor Type Winbond W83627EHF (ISA 290h)
Motherboard Name Asus P4GD / P4GPL / P5AD / P5GD / P5P800 Series
Temperatures:
Motherboard 42 °C (108 °F)
CPU 42 °C (108 °F)
WDC WD800JD-00LUA0 25 °C (77 °F)
Cooling Fans:
CPU 2360 RPM
Chassis 2150 RPM
Voltage Values:
CPU Core 1.58 V
+3.3 V 3.41 V
+5 V 5.70 V
+12 V 12.22 V
+5 V Standby 5.19 V
Debug Info F 9D 8F FF
Debug Info T 42 42 35
Debug Info V B5 E9 D5 D4 FF C9 A5 (03)
CPU
CPU Properties:
CPU Alias Prescott
CPU Stepping E0
Instruction Set x86, MMX, SSE, SSE2, SSE3
Original Clock 3000 MHz
Min / Max CPU Multiplier 14x / 15x
L1 Data Cache 16 KB
Multi CPU:
Motherboard ID INTEL
CPU #0 Intel(R) Pentium(R) 4 CPU 3.00GHz, 3010 MHz
CPU #1 Intel(R) Pentium(R) 4 CPU 3.00GHz, 3010 MHz
CPUID
CPUID Properties:
CPUID Manufacturer GenuineIntel
IA Brand ID 00h (Unknown)
Platform ID 13h (Socket 775)
IA CPU Serial Number Unknown
Microcode Update Revision 17
HTT / CMP Units 2 / 1
Instruction Set:
64-bit x86 Extension (AMD64, EM64T) Not Supported
Alternate Instruction Set Not Supported
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
IA SSE 3 Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
MONITOR / MWAIT Instruction Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Not Supported
SYSENTER / SYSEXIT Instruction Supported
VIA FEMMS Instruction Not Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Data Execution Prevention (DEP, NX, EDB) Not Supported
Hardware Random Number Generator (RNG) Not Supported
Montgomery Multiplier & Hash Engine Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Automatic Clock Control Supported
Enhanced Halt State (C1E) Supported, Enabled
Enhanced SpeedStep Technology (EIST, ESS) Not Supported
Frequency ID Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Supported
Thermal Monitor 2 Not Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features:
36-bit Page Size Extension Supported
Address Region Registers (ARR) Not Supported
CPL Qualified Debug Store Supported
Debug Trace Store Supported
Debugging Extension Supported
Fast Save & Restore Supported
Hyper-Threading Technology (HTT) Supported, Enabled
L1 Context ID Supported
Local APIC On Chip Supported
Machine Check Architecture (MCA) Supported
Machine Check Exception (MCE) Supported
Memory Configuration Registers (MCR) Not Supported
Memory Type Range Registers (MTRR) Supported
Model Specific Registers (MSR) Supported
Page Attribute Table (PAT) Supported
Page Global Extension Supported
Page Size Extension (PSE) Supported
Pending Break Event Supported
Physical Address Extension (PAE) Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Supported
Time Stamp Counter (TSC) Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
Motherboard
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 200 MHz (QDR)
Effective Clock 800 MHz
Bandwidth 6400 MB/s
Memory Bus Properties:
Bus Type DDR2 SDRAM
Bus Width 64-bit
Real Clock 200 MHz (DDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Chipset Bus Properties:
Bus Type Intel Direct Media Interface
Motherboard Physical Info:
CPU Sockets/Slots 1 Socket 775
Expansion Slots 3 PCI, 3 PCI-E x1, 1 PCI-E x16
RAM Slots 4 DDR2 DIMM
Integrated Devices Audio, Gigabit LAN
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset i915P
Extra Features JumperFree, Stepless Freq Selection
Motherboard Manufacturer:
Company Name ASUSTeK Computer Inc.
Product Information
http://www.asus.com/products1.aspx?l1=3
BIOS Download
http://support.asus.com/download/dow...Language=en-us
Memory
Physical Memory:
Total 1535 MB
Used 427 MB
Free 1108 MB
Utilization 28 %
Swap Space:
Total 3434 MB
Used 320 MB
Free 3113 MB
Utilization 9 %
Virtual Memory:
Total 4970 MB
Used 748 MB
Free 4221 MB
Utilization 15 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active No
SPD
[ DIMM1: Xerox MALABS ]
Memory Module Properties:
Module Name Xerox MALABS
Serial Number None
Manufacture Date Week 38 / 2004
Module Size 1024 MB (2 ranks, 4 banks)
Module Type Unbuffered
Memory Type DDR2 SDRAM
Memory Speed DDR2-533 (266 MHz)
Module Width 64 bit
Module Voltage SSTL 1.8
Error Detection Method None
Refresh Rate Reduced (7.8 us)
Memory Timings:
@ 266 MHz 5.0-4-4-11 (CL-RCD-RP-RAS)
@ 266 MHz 4.0-4-4-11 (CL-RCD-RP-RAS)
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS)
Memory Module Features:
Early RAS# Precharge Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
[ DIMM2: Samsung M3 78T6553BG0-CCC ]
Module Name Samsung M3 78T6553BG0-CCC
Serial Number 45070DA4h
Manufacture Date Week 25 / 2004
Module Size 512 MB (1 rank, 4 banks)
Memory Speed DDR2-400 (200 MHz)
Module Width 64 bit
Memory Timings:
@ 200 MHz 5.0-3-3-8 (CL-RCD-RP-RAS)
@ 200 MHz 4.0-3-3-8 (CL-RCD-RP-RAS)
Memory Module Manufacturer:
Company Name Samsung
Product Information
http://www.samsung.com/Products/Semi...DRAM/index.htm
Chipset
[ North Bridge: Intel Grantsdale i915P ]
North Bridge Properties:
North Bridge Intel Grantsdale i915P
Revision / Stepping 04 / B1
Package Type 1210 Pin FC-BGA
Package Size 3.75 cm x 3.75 cm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Controller:
Type Dual Channel (128-bit)
Active Mode Single Channel (64-bit)
Memory Timings:
CAS Latency (CL) 3T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 8T
Error Correction:
ECC Not Supported
ChipKill ECC Not Supported
RAID Not Supported
ECC Scrubbing Not Supported
Memory Slots:
DRAM Slot #1 1024 MB (DDR2 SDRAM)
DRAM Slot #2 512 MB (DDR2 SDRAM)
PCI Express Controller:
PCI-E x16 port #2 In Use @ x16 (nVIDIA GeForce 6600 PCI-E Video Adapter)
Chipset Manufacturer:
Company Name Intel Corporation
Product Information
http://www.intel.com/products/browse/chipsets.htm
Driver Download
http://support.intel.com/support/chipsets/index.htm
[ South Bridge: Intel 82801FB ICH6 ]
South Bridge Properties:
South Bridge Intel 82801FB ICH6
Revision / Stepping D3 / B1
Package Type 609 Pin mBGA
Package Size 3.1 cm x 3.1 cm
Core Voltage 1.5 V
High Definition Audio:
Audio Controller Type Intel 82801FB(M) ICH6
Codec Name C-Media CMI9880
Codec ID 434D4980h
Codec Revision 00090402h
PCI-E x1 port #1 Empty
PCI-E x1 port #2 In Use @ x1 (Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller)
Windows Video
[ NVIDIA GeForce 6600 ]
Video Adapter Properties:
Device Description NVIDIA GeForce 6600
Adapter String GeForce 6600
BIOS String Version 5.43.02.16.31
Chip Type GeForce 6600
DAC Type Integrated RAMDAC
Installed Drivers nv4_disp (6.14.10.8198 - nVIDIA ForceWare 81.98)
Memory Size 256 MB
Video Adapter Manufacturer:
Company Name NVIDIA Corporation
Product Information
http://www.nvidia.com/view.asp?PAGE=products
Driver Download
http://www.nvidia.com/content/drivers/drivers.asp
PCI / AGP Video
Device Description Device Type
nVIDIA GeForce 6600 PCI-E 3D Accelerator
GPU
[ PCI Express x16: nVIDIA GeForce 6600 PCI-E ]
GPU Code Name NV43
PCI Device 10DE / 0141
Transistors 143 million
Process Technology 0.11u
Die Size 150 mm2
Bus Type PCI Express x16 @ x16
Memory Size 256 MB
GPU Clock 299 MHz
RAMDAC Clock 400 MHz
Pixel Pipelines 8
TMU Per Pipeline 1
Vertex Shaders 3 (v3.0)
Pixel Shaders 1 (v3.0)
DirectX Hardware Support DirectX v9.0c
Pixel Fillrate 2392 MPixel/s
Texel Fillrate 2392 MTexel/s
Bus Type DDR
Bus Width 128-bit
Real Clock 250 MHz (DDR)
Effective Clock 501 MHz
Bandwidth 8016 MB/s
Graphics Processor Manufacturer:
Product Information
Driver Download
It has taken me sometime to build my PC I also have a 550w PS but generic lol also am I able to notice a super big dieffrence if the dual channelness thing is restored? sorry for this long post but I have looked at others when going to rate and they always forget something so I hope i got it all and I hope I don't annoy anyone with this super long post thanks guys your the greatest !
