Boot Problem...
Currently Active Users: 2296
Discussions: 200,937, Posts: 2,379,255, Members: 246,302
Old April 27th, 2006, 05:35 PM   Digg it!   #1 (permalink)
Exclamation
Boot Problem...
OK, when i turn on my PC it will say F11 to boot, or F2 to go to BIOS...I put my windows CD in and it goes to a screen saying... NRLDT missing or something along those borders! How do i get my windows CD to install! Please help! Thanks, and thank you for all the help..Im almost done!
HD:80GB Seagate Barracuda + 40GB Seagate IDE
CPU:AMD Athlon 64 3200+ Venice @2.0Ghz
GPU:7600GT
Case:Aspire X-Cruiser
RAM:Patriot Signature 2X512
Bgator is offline   Reply With Quote
Old April 27th, 2006, 05:45 PM     #2 (permalink)
:slack: strong
Detritus's Avatar
Send a message via MSN to Detritus Send a message via Yahoo to Detritus
Okay, do you have a floppy in the floppy drive, if you even have a floppy drive? Do you have the CD/DVD ROM set as the primary boot device?
Detritus is offline   Reply With Quote
Old April 27th, 2006, 05:48 PM     #3 (permalink)
No i dont have a floppy in the drive but yes i have one, and yes i changed CD-Drive to primary boot....
Old April 27th, 2006, 06:15 PM     #4 (permalink)
Super F@D Folder
it should pop up at some point and say press any key to boot to cd. If you don't see that then you need to go into the bios and make sure both the cd drive and harddrive are both recognised! Then, you need to make sure u'r set to boot to cd first, then floppy, then harddrive preferably. the most important though is the cd first...if the harddrive is second and whatever then that's fine....cd first!! lol. Once that's all set you should deff see the press any key to boot to cd message, and if not, then we have other issues.
Old April 27th, 2006, 06:50 PM     #5 (permalink)
How do i tell if it recognizes my CD drive, the CD drive light turns on...But is there somewhere in BIOS that will tell me where! Thanks! And hpw do i reformat my HD?!
Old April 27th, 2006, 08:40 PM     #6 (permalink)
Does anyne have any other suggestions like reformatting? When i turn on my comp it boots to my old XP which will not work on my new comp...I need to erase that XP Please help!
Old April 27th, 2006, 08:51 PM     #7 (permalink)
As stated above, set boot order to boot from CD-ROM as "first boot device." I set my other devices to "disabled," but not everyone will do that. It's a little redundant I suppose. Anway, XP CD-ROM will prompt for formatting.
Zoltar is offline   Reply With Quote
Old April 27th, 2006, 09:21 PM     #8 (permalink)
It's the cheese guy! ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
Press F11 and select your CD rom as the booting device in the menu that pops up. Remember to look out for the "Press any key to boot from CD" message. You only get a few seconds.
paul9 is offline   Reply With Quote
Old April 27th, 2006, 09:37 PM     #9 (permalink)
when i press F11 the CD isnt an option :/
Old April 27th, 2006, 10:03 PM     #10 (permalink)
Ok, i got it to work, one of my IDE ribbon cables was bad...:/ im embarassed thanks for all help!
Boot Problem slinky Storage Related 10 July 14th, 2005 10:00 AM
Boot up problem.. i need help!! secnpa Technical Support 1 July 2nd, 2005 01:13 AM
1)BOOT problem, 2)user's folder access problem baxteras Applications and Operating Systems 5 September 5th, 2004 08:45 AM
Hd boot problem ConCReeD Technical Support 7 September 2nd, 2004 07:07 AM
Windows Problem :: Boot Up Problem :: Please Help! ConquerorX General Tech Discussion 4 June 11th, 2003 10:14 PM
Is It Just Me? (2908)
Wireless Televisions. (8)
Obama the Muslim (14)
Have you switched yet? (85)
Regular Build (4)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
Optical Audio A-B Switch (1)
