Results 1 to 13 of 13
    Senior Member dustyrun's Avatar
    Louisville,KY
    564
    Question Upgrade: SDram or DDram?
    Hey Folks,
    I currently have:
    PIII-1gig
    512 meg sdram
    hard drive-40 gig
    hard drive- 27 gig
    sould blaster live 5.1
    Liteon DVD/48x CDrom
    Plextor 16-12-40
    Radeon 8500
    altec lancing 4.1 speakers
    Viewsonic PF790 19"
    I am going to upgrade to a 1.9 gig. I will see a large improvement no matter which way i go on the ram.
    When i upgrade it will have all the same parts as above except for the following:
    PIV-1.9 gig
    Motherboard- {have not decided yet due to ram question}
    512 meg ram
    My question is with me doing a major upgrade would it be advisable to go to the DDRam or us the SDRam at 133?
    The price difference would be about $100 between the board and the ram.
    Is it worth it????
    thank in advance,
    Rick
    Note: it is used for heavy 2d cad work mainly.
    Dec 2001
    Germany
    324
    I would upgrade the ram, too DDR I have a AMD system running 768mb of DDR. With the OC possiblities of a P4 I would go with DDR just to max the combo of ram/cpu to the point of instability.
    RYO
    Ryo
    Ultimate Member willy_ph's Avatar
    Trent University
    2,414
    If you're moving to a 1.9 gig P4, you'll definately notice a dramatic improvement if you DDR ram rather than SD ram.
    If it was me making the decision I would go the DDR route.
    The difficulty is to try and teach the multitude that something can be true and untrue at the same time. -- Arthur Schopenhauer
    Ultimate Member AuraEdge's Avatar
    Clifton, NJ
    5,066
    The PIV needs high ram speeds to perform well. It is much more RAM intensive than either the Athlon or the P3.
    http://www6.tomshardware.com/mainboa.../i845d-05.html
    Unfortunately, I couldnt find any benchmarks putting the P4 SDR SDRAM (i845) solution against a high speed P3...its all P4 vs Athlon these days
    Ultimate Member ocit's Avatar
    So. Cali
    1,536
    ddr , step into the future. lol
    -JOSH H2OL-
    Louisville,KY
    564
    Thanks for the quick reply.
    Looks like i will be getting ddram for this upgrade.
    By the way it has XP Pro on it.
    Again thanks.
    Rick
    Ultimate Member ironforge's Avatar
    1,119
    Yes.. if at all possible go with DDR because it is more speedy
    Louisville,KY
    564
    well folks,
    I finally did it. I got my first Athlon.
    Athlon 2000+
    Asus A7V266 MotherBoard
    512 Kingston ddram
    Antec 1030 case
    and all the components listed above.
    in 3dmark2001 the score raised from 5600 to 7400. no o'clocking
    Trent University
    2,414
    Good cal dustyrun. Welcome to the otherside.
    Louisville,KY
    564
    iguess i finally when and did it!!!!!
    got hold of
    1: asus a7v motherboard
    2: 512 meg pc2100 kingston
    3: athlon xp 2000+
    works like a charm so far. installed and open office 2000 pro in 5 min 15 sec.
    sounds like a killer to me.
    Any Good Guys?????
    I have always run in an antec 1030 case with all fans included.
    Ultimate Member Emc2's Avatar
    Savannah, GA
    1,752
    Just keep it cool...you're not using the stock fan on that are you? Good choice with 512MB of RAM with WinXP--now get rid of your swap file.
    My R&D machine:
    AMD 2100+ @ 2700+
    Asus A7N8X-E
    1GB Kingston PC333
    2xWD 74GB Raptor's in SATA RAID
    ATI 9700Pro w/ Zalman Heat Pipe
    Senior Member thekemp's Avatar
    Nov 2001
    manchester uk
    939
    i currently have a sis 645 based mobo with pc2700 memory(333) this is nearlly as fast as rambus for a cheaper price. if your getting a 1.9 p4 DDR 2100 memory should be fast enough to not choke the p4 too much.
    Ultimate Member EvilRick's Avatar
    N of Music City, USA
    7,832
    Originally posted by ironforge
    more speedy
    I personally would have said...more faster.
