Toshiba A15-S1292
Currently Active Users: 1555
Discussions: 200,925, Posts: 2,379,128, Members: 246,291
Old May 10th, 2006, 02:57 AM   Digg it!   #1 (permalink)
Toshiba A15-S1292
I just bought this Toshiba A15-S1292 from the private party.
celeron 2.4ghz, 512, 30g hard drive. cdr/dvd combo.
It does work OK till 2 hours and drop.
fan work. after 2 hours of work the unit become slow response, and
after a while, it become the blue screen with fatal error, and shuting down .
The seller bought this as 2nd hand about 6months ago.
She never experienced the problem .
The seller never used this more than 1 hour at a time.
The add for this unit was sold as is .
I did ask the seller for retuning this item, but declined.
Does the seller have any liability for not testing this unit for more than 2 hours??
Could I do something about this??
Thank you in advance,
golf007
golf007 is offline   Reply With Quote
Old May 10th, 2006, 04:12 PM     #2 (permalink)
Thank you Steve.
I will check the error message and try with that information on that links.
I also check the some information about this computer, I found there is some over heating issue for Toshiba laptop. I could not find this exact model A15 though.
golf007
Old May 11th, 2006, 02:32 PM     #3 (permalink)
Write sector error device=126
Now I have this message and even can not re-install the factory CD(OS).
please help.
Got an A15-S127 laptop cheap with no operating system. rabidaardvark Linux and Unix 7 May 5th, 2005 11:57 AM
Which Toshiba? minduka Mobile Computing 4 March 4th, 2004 06:01 AM
New Toshiba? Skay Mobile Computing 0 October 15th, 2003 05:56 PM
Toshiba notebook (A15-S127) $699 Boat ResellerRatings Homepage Deals 1 September 9th, 2003 07:02 PM
Toshiba????? goldpag Mobile Computing 4 June 15th, 2002 02:32 AM
Is It Just Me? (2865)
Obama the Muslim (14)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
