Results 1 to 5 of 5
    May 2004
    151
    Geforce 6200 question
    I bought a XFX Geforce 6200 256MB AGP video card and send it to a friend. He said the card works ok except for his cpu running at 100%.
    Here is his note: "The card work ok,, the only problem is each time i change a setting in the card or my desktop setting, it run my cpu at 100% from 30c up to 80c for 10min without stoping, and i have to reboot. Once i reboot it is ok I update the driver,but no change. thank again kool"
    Any suggestion why his system acts the way it does?
    SYSTEM CONFIGURATION
    Operating System System Model
    Windows XP Professional Service Pack 2 (build 2600) Enclosure Type: Desktop
    Processor a Main Circuit Board b
    2.80 gigahertz Intel Pentium 4
    16 kilobyte primary memory cache
    256 kilobyte secondary memory cache Board: i848P-627HF
    Bus Clock: 133 megahertz
    BIOS: Phoenix Technologies, LTD 6.00 PG 01/05/2005
    Drives Memory Modules c,d
    80.02 Gigabytes Usable Hard Drive Capacity
    63.51 Gigabytes Hard Drive Free Space
    PLEXTOR DVDR PX-716A [CD-ROM drive]
    3.5" format removeable media [Floppy drive]
    Generic USB CF Reader USB Device [Hard drive] -- drive 2
    Generic USB MS Reader USB Device [Hard drive] -- drive 4
    Generic USB SD Reader USB Device [Hard drive] -- drive 1
    Generic USB SM Reader USB Device [Hard drive] -- drive 3
    WDC WD800BB-55JKA0 [Hard drive] (80.03 GB) -- drive 0, s/n WD-WMAMD1425388, rev 05.01C05, SMART Status: Healthy 640 Megabytes Installed Memory
    Slot 'A0' has 512 MB
    Slot 'A1' has 128 MB
    Slot 'A2' is Empty
    Slot 'A3' is Empty
    Local Drive Volumes
    c: (NTFS on drive 0) 26.21 GB 10.71 GB free
    d: (NTFS on drive 0) 53.80 GB 52.80 GB free
    Network Drives
    None detected
    Users (mouse over user name for details) Printers
    local user accounts last logon
    jaya 5/19/2006 7:40:32 PM (admin)
    local system accounts
    Administrator never (admin)
    Guest never
    HelpAssistant never
    SUPPORT_388945a0 never
    Marks a disabled account; Marks a locked account EPSON Stylus C43 Series on USB001
    Microsoft Office Document Image Writer Driver on Microsoft Document Imaging Writer Port:
    Controllers Display
    Standard floppy disk controller
    Intel(R) 82801EB Ultra ATA Storage Controllers (2x)
    Primary IDE Channel [Controller] (2x)
    Secondary IDE Channel [Controller] (2x) NVIDIA GeForce 6200 [Display adapter]
    JEN JD144 [Monitor] (13.5"vis, s/n 7031DB002155, July 2000)
    Bus Adapters Multimedia
    Intel(R) 82801EB USB Universal Host Controller - 24D2
    Intel(R) 82801EB USB Universal Host Controller - 24D4
    Intel(R) 82801EB USB Universal Host Controller - 24D7
    Intel(R) 82801EB USB Universal Host Controller - 24DE
    Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD ESS 1969 PCI AudioDrive (WDM)
    Pinnacle DV/AV
    Standard Game Port
    Communications Other Devices
    Motorola USB Modem
    1394 Net Adapter
    Realtek RTL8139/810x Family Fast Ethernet NIC
    Dhcp Server: none responded
    Physical Address: 00:01:29:FE:09:60
    OHCI Compliant IEEE 1394 Host Controller
    Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    PS/2 Compatible Mouse
    USB Mass Storage Device
    USB Root Hub (5x)
    Virus Protection [Back to Top]
    AVG Anti-Virus 7.1.375 Version 7.1.375
    Realtime File Scanning On
    Human voltmeter DanU's Avatar
    SF Bay Area
    4,214
    Go into your task manager and find out which exact process is eating up the CPU cycles. Post back here with your findings.
    分かりますか。 carl33p's Avatar
    Feb 2006
    Gville, FL
    7,170
    9
    Quote Originally Posted by cman900
    Are those temps? And of the CPU or GPU?
    I doubt his temps jump that extreme.
    May 2004
    151
    Here is some more info on my friend graphics card problen
    nvidia support......
    CPU usage is at 99% (rscmpt.exe)
    Question
    After installing the display drivers, my CPU usage is at 99%. The
    file
    'rscmpt.exe' seems to be the cause. When this file is removed, my
    total
    video memory is lower than what it should be. How do I fix this?
    Answer
    The file "rscmpt.exe" is not part of the NVIDIA Forceware unified
    driver
    package. This file has been found packaged with drivers for other
    graphic
    card vendors. The file doubles the amount of video memory reported by
    Microsoft Windows and consumes around 99% of a computer's CPU. We do
    not
    know the source of this file but if it was installed on your system, it
    should be removed. If your graphics card video memory drops from specs
    listed by your graphics card manufacturer, please contact the retailer
    where
    you purchased your graphics card.
    New Problem
    i could not find the file so i reinstall windows xp it is ok now...but
    it is freezing up every minute with a buzzing sound in the speaker
    when i try to open some of my programs .
    I put my old video card in and the programs open up not has pretty as
    the new card but with no freezing up.
    I am still using the new card it is faster and the graphic is pretty,
    when it freeze i just reboot every time ( kool )
    Any suggestion
    SF Bay Area
    4,214
    Are you using the latest drivers from Nvidia's web page?
    Have you also updated your motherboard's chipset drivers?
    You may be overheating. Check the temp of your CPU using Everest Home. Also check the temp of your graphics card. It should be in your graphics card control panel.
    Do you meet the power supply requirments for the 6200? What is the brand and wattage of your power supply?
  1. XFX GeForce 6200
    By cman900 in forum General Tech Discussion
    Last Post: May 9th, 2006, 03:01 PM
  2. GeForce 6600 with 6200 chipset?!
    By ljb999 in forum Graphics Cards and Displays
    Last Post: December 2nd, 2005, 07:57 PM
  3. geforce 6200 pci-e
    By kenji101 in forum Graphics Cards and Displays
    Last Post: July 15th, 2005, 10:05 AM
  4. GeForce FX GO 6200 Questions
    By FatalException in forum Graphics Cards and Displays
    Last Post: June 29th, 2005, 03:53 PM
  5. TV-Out on Asus Geforce 6200
    By byunews in forum Graphics Cards and Displays
    Last Post: March 25th, 2005, 02:50 PM
