slow/freezing up computer
Currently Active Users: 1242
Discussions: 200,929, Posts: 2,379,146, Members: 246,296
Old June 12th, 2006, 02:18 PM   Digg it!   #1 (permalink)
Angry
I just downloaded Norton Anitvirus 2006 last week my computer keeps freezing up and wont respond . Whats up?
dzasa256 is offline   Reply With Quote
Old June 12th, 2006, 03:01 PM     #2 (permalink)
Send a message via AIM to CharmedLover84
Okay. Is your computer overclocked, is the room getting hotter because of the summer, and is the AntiVirus constantly using CPU %? Answer those and you might actually get some answers to your question cuz it's kinda vague What's your system setup?
CharmedLover84 is offline   Reply With Quote
Old June 12th, 2006, 03:01 PM     #3 (permalink)
nomaxim's Avatar
You could try Symantec's Autofix to see if somethimg is wrong with the install.
http://www.symantec.com/techsupp/home_homeoffice/index_ts.html
or other support/help. Norton is known to cause problems with some systems.
And as above , some more info would be helpful.
And Welcome to TechIMO.
EDIT;
Forgot the link for the Help/support, http://www.symantec.com/techsupp/hom...ice/index.html
Well, if crime fighters fight crime and fire fighters fight fire, what do freedom fighters fight? They never mention that part to us, do they?
-George Carlin
nomaxim is offline   Reply With Quote
Old June 13th, 2006, 11:23 AM     #4 (permalink)
Angry
computer not responding
I uninstalled the Norton antivirus from my system, my computer will not respond when I double click on a desktop shortcut it doesnt do anything at all
Old June 13th, 2006, 11:46 AM     #5 (permalink)
A#1
to rule out a possible mouse problem...look at your desktop and type the first letter of any shortcut on your desktop...i.e. (My Computer)...type the letter "M" one time...this will highlight the 'My Computer' icon then use the keyboard key on the lower righthand side of your keyboard to the right of your windows key...this key is the same as right clicking a mouse...you can use your cursor...arrow keys to navigate through the properties menu and try and open a program that way...if this works...look at repairing your mouse drivers
A#1 is offline   Reply With Quote
Old June 13th, 2006, 12:54 PM     #6 (permalink)
分かりますか。
carl33p's Avatar
Send a message via AIM to carl33p
I would try doing a System Restore to an earlier date.
Press Start button > Programs > Accessories > System Tools > System Restore
Restore to a date before you had Norton on ur PC.
See this thread for additional help.
http://www.techimo.com/forum/t163571.html
Theres Norton removal help here.
carl33p is offline   Reply With Quote
Computer freezing AmanteImperfetto General Tech Discussion 11 July 15th, 2005 09:24 AM
My Computer Keeps Freezing! Heavencent Technical Support 11 September 23rd, 2004 01:47 AM
Computer Keeps on Freezing mastavic Applications and Operating Systems 4 August 26th, 2004 03:44 AM
Computer keeps freezing!?! imgreedy Technical Support 7 September 9th, 2003 03:45 AM
Slow computer, dumb computer, troubled computer, who knows!! HelpPlease Technical Support 31 April 13th, 2002 09:12 PM
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (2)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
