Bag a Credit Card??
Currently Active Users: 1490
Discussions: 200,930, Posts: 2,379,154, Members: 246,297
Old August 27th, 2006, 01:27 PM   Digg it!   #1 (permalink)
No pants, Wearin'a Helmet
MitaDC's Avatar
Send a message via ICQ to MitaDC Send a message via MSN to MitaDC Send a message via Yahoo to MitaDC
Bag a Credit Card??
Hey guys, just wondering:
Why do sometimes credit cards not run but they will work if you put a plastic bag over them and run them through? This always happens to one of my cards (brand new card)??
Mita
Dr. Cox -Newbie, Stay. Oohhh what a good boy you are, Newbie..... DEAR GOD JUDY HOW MUCH PRODUCT DO YOU USE?
J.D -None. It's like this when I wake up
MitaDC is offline   Reply With Quote
Old August 27th, 2006, 02:05 PM     #2 (permalink)
Super F@D Folder
i've never heard of that before...put a bag over a credit card to make it work?? interesting
Old August 27th, 2006, 02:23 PM     #3 (permalink)
SeanC's Avatar
I've had that happen. If you put a piece of scotch tape of the mag stripe it will work while normally it doesn't. It's mainly due to surface damage to the card over the mag stripe, it makes it nearly impossible for the reader to get it properly.
I'm not sure how this really fixes it since I'm no expert in that.
AMD Phenom Q9500 Quad-Core 2.2ghz / Asus M3A78-EMH HDMI / 4GB PC667 RAM / 320GB SATA II
SeanC is offline   Reply With Quote
Old August 27th, 2006, 02:29 PM     #4 (permalink)
Send a message via AIM to RamonGTP Send a message via MSN to RamonGTP Send a message via Yahoo to RamonGTP
yep, happened to me several times, don't know why it works either... Try google
RamonGTP is offline   Reply With Quote
Old August 27th, 2006, 02:50 PM     #5 (permalink)
Improves contact with the reader?
Mr. Jiggyfly, I have good news...
mr.jiggyfly is offline   Reply With Quote
Old August 27th, 2006, 03:22 PM     #6 (permalink)
RayH's Avatar
I'd order a new card
TheGreatRaymond@sbcglobal.net
Please indicate you are from TechIMO in subject line so you don't get deleted as spam :)
RayH is offline   Reply With Quote
Old August 27th, 2006, 04:58 PM     #7 (permalink)
wera's Avatar
Send a message via AIM to wera Send a message via MSN to wera Send a message via Yahoo to wera
As Shawn says Scotch tape works.
wera is offline   Reply With Quote
Old August 27th, 2006, 05:02 PM     #8 (permalink)
Administrator
ScottW's Avatar
I was in line at a grocery store one time and the customer ahead of me presented a card to the clerk that had been cut in half. She claimed her kid had cut it in two - year right. The clerk didn't even hesitate to hold the two pieces of the card together and try to swipe it - then they tried tape and also the plastic bag trick. Never worked . I then proceeded to switch lines .
ScottW is offline   Reply With Quote
Old August 27th, 2006, 05:12 PM     #9 (permalink)
HeadBand's Avatar
I had a manager card that was cut in half....I have no clue what happened to the other half but the one I had still worked on its own
Hey who turned sigs on?
Old August 27th, 2006, 05:42 PM     #10 (permalink)
SeanC's Avatar
That's why clerks aren't supposed to accept cards that are in pieces.
If they validate that the card is legit, then they manually enter the number. All POS devices include the ability to manually enter the card number, it's an Interac requirement in Canada and it should be a requirement anywhere.
My first credit card... RunAboveIt IMO Community 27 August 8th, 2006 11:00 AM
What's your credit card APR %? sixf00t4 IMO Community 3 June 30th, 2005 10:02 AM
0% Credit Card Offer MTAtech IMO Community 15 May 24th, 2005 08:58 PM
Can I get a credit card? Blazer06 IMO Community 1 July 16th, 2004 12:10 AM
Is It Just Me? (2870)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
