Thread: DOA PSU (EZcool 500W)
October 13th, 2006, 01:00 AM #1Junior Member
- Oct 2006
- 4
Hi all,
First post for me. Just took delivery of a new PSU (EZcool 500W) for a new system I'm building. Plugged it into power and expected fan to spin. NOTHING !!
Checked lead in another puter and all was fine.
I'm not big on electrics and was wondering if the PSU has to be earthed in a case to work and not just sitting on a bench.
October 13th, 2006, 01:14 AM #2
While most supplies should power up (turn on) with no load such as what you are trying, some will flat out refuse to while others will some of the time. I suggest you try plugging in a couple of fans and/or maybe a couple of drives to put a load on the supply.
/edit
Of course you will need to tell the supply to turn on. There are a couple of pins on the connector that you will need to jumper for this to happen and right off the top of my head I can't remember which ones.......I'll see if I can find it.....
//edit
Pin 13 to 14... black to green (or should be)Last edited by jrsweger; October 13th, 2006 at 01:23 AM.
October 13th, 2006, 05:34 AM #3
Is the 110/220 switch in the correct position?
Sometimes incorrect voltage will cause the power supply to just sit there instead if burning it out.
Also remove all drive connections...just the mobo connection to start out with.
Help Please! Mobo DOA?
By rattle2k in forum MotherboardsReplies: 19Last Post: April 18th, 2006, 09:34 AM -
what 500w+ psu?
By Micky758 in forum Processors, Memory, and OverclockingReplies: 16Last Post: April 1st, 2005, 01:16 PM -
Is my pc DOA?
By jimzap in forum MotherboardsReplies: 11Last Post: December 8th, 2003, 10:45 PM -
ELSA... DOA
By wavefront in forum Graphics Cards and DisplaysReplies: 15Last Post: July 29th, 2002, 10:59 AM -
500w PSU...questions?
By Sweeper in forum General Tech DiscussionReplies: 5Last Post: April 20th, 2002, 12:49 PM
holy crapppppppppppppppppp its nice outside!!
