Results 1 to 4 of 4
    Oct 2006
    2
    Unhappy Toshiba T3200 issue
    Hi. I hope someone can give me some good advice. I have an old unit, a Toshiba T3200 Laptop. Heavy as all hell, but this is not the issue. I receive the following errors on this laptop:
    **** Error in CMOS. Bad Check Sum ****
    *** Error in CMOS. Bad memory size ***
    Check system. Then, press [F1] key .....
    Warning: Default setupwill be set into CMOS memory.
    Hit F1
    "When I hit F1 this is what I get next"
    Bad or missing command interpreter
    What is the issue? Bad CMOS battery possibly?
    Any Help is appreciated
    Nov 2006
    Sweden
    6
    I have the same startup problem with CMOS except I get
    **** Error in CMOS. Bad Battery **** as well.
    The "Bad or missing command interpreter" should indicate that there is no COMMAND.COM in you root directory. You should be able to use a bootdisk to access the HD and maybe reinstall the OS.
    After searching the entire net for T3200 I found ways to get into the BIOS for almost every other computer on the planet but not the T3200. But stubborn as I am I tested all kinds of key combinations and the one that worked was: Ctrl+Alt+F10 - not much to change except what HD you have, installed memory and if you have an external display card.
    I'd really like to max my T3200 out, but I guess the only way to do that is to look for damaged machines for spare parts...
    May 2012
    CHASC
    I HAVE TWO TOSHIBA T3200 PORTABLE PCS COMPLETE WITH CASE AND MANUELS .THEY LOOK LIKE THEY ARE IN GOOD SHAPE BUT I DON'T HAVE A CLUE HOW TO OPERATE OR TEST.SELLING AS IS FOR PARTS .CAN SEND PICTURES IF INTERESTED .MAKE ME AN OFFER FOR ONE OR BOTH OF THEM.
    CHAS
    e-mail chas629329@yahoo.com
    Banned
    Feb 2009
    KFNL FS2004
    11,885
    This is a six year old thread. You won't get a reply and reseller ratings is where you should post this.
  1. Issue with Toshiba Satellite Fans
    By dblwide in forum General Tech Discussion
    Last Post: April 10th, 2005, 03:06 PM
  2. Toshiba Satellite Issue
    By N0EXCUSE2 in forum Technical Support
    Last Post: October 4th, 2004, 10:42 PM
  3. Which Toshiba?
    By minduka in forum General Tech Discussion
    Last Post: March 4th, 2004, 06:01 AM
  4. New Toshiba?
    By Skay in forum General Tech Discussion
    Last Post: October 15th, 2003, 04:56 PM
  5. Toshiba?????
    By goldpag in forum General Tech Discussion
    Last Post: June 15th, 2002, 01:32 AM
