Blue Screen of Death problem
Currently Active Users: 2282
Discussions: 200,942, Posts: 2,379,287, Members: 246,305
Old November 11th, 2006, 03:01 AM   Digg it!   #1 (permalink)
Send a message via AIM to jmreedy Send a message via MSN to jmreedy
Question
Hey IMOers,
Recently built a computer for a friend and just recently it has been crashing to the blue screen of death. I have copied over the message that I get and it is posted below. Also during the POST I get a message that says "No Any Drivers Found" I believe this could be the base of my problem. I noticed that a few other people have also had this issue but none of their posts has helped figure out how to get rid of it. Specs are also listed below, Thanks guys!
DRIVER_IRQL_NOT_LESS_OR_EQUAL
Technical Information
STOP: 0x0000000D1 (0x00000004, 0x00000002, 0X00000001, 0xB731B1EA)
wind502u.sys - Address B731B1EA base at B72EB000, DateStamp 406329d2
Beginning dump of physical memory
Physical memory dump complete.
Contact yoru system administrator or technical support group for further assistance.
ASUS M2N-SLI Deluxe Socket AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard
AMD Athlon 64 X2 4200+ Windsor 2.2GHz Socket AM2 Processor
eVGA 512-P2-N637-AR GeForce 7950GT 512MB GDDR3 PCI Expres
Rosewill RP550V2-S-SL 550W SLI Ready-ATX 12V V2.01 Power Supply
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 675 (PC2 5400)
SAMSUNG 18X DVD±R DVD Burner
LITE-ON Black ATAPI/E-IDE DVD-ROM
Western Digital Caviar SE16 WD3200KS 320GB 7200 RPM SATA
jmreedy is offline   Reply With Quote
Old November 11th, 2006, 06:57 AM     #2 (permalink)
BluesMan1's Avatar
This wind502u.sys seems to be related to a wireless adaptor. Take a look in Safe Mode System > Hardware > Device Manager and see if there is any problems with your wireless adaptor, maybe you'll have to get the drivers from the manufacturer web site and reinstall it.
Hope this help
BluesMan1 is offline   Reply With Quote
Old November 11th, 2006, 10:56 AM     #3 (permalink)
Thanks, I will try that. She currently has the Motorola WU830G USB adapter and the drivers were in fact out dated, hopefully this solves my problem.
I also had Hamachi on the computer, I uninstalled it at the moment to be safe but do you think the problem could have anything to do with that?
Blue Screen of Death twax General Tech Discussion 11 June 15th, 2005 04:19 PM
Blue Screen of Death Rdaws General Tech Discussion 11 May 31st, 2005 04:45 PM
blue screen of death!?!?! skeltonjoe Technical Support 3 March 27th, 2005 12:30 PM
blue screen of death mark146914 General Tech Discussion 3 February 3rd, 2004 01:43 AM
Blue screen of death unilady6767 Technical Support 11 August 1st, 2003 02:52 AM
Is It Just Me? (2917)
Wireless Televisions. (9)
Regular Build (6)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
