Page 1 of 2 1 2 LastLast
Results 1 to 20 of 26
    Jan 2007
    15
    About to build my PC :D
    Shipment of my parts should come today, and I'm excited to make my FIRST build. Any tips or videos to help me along the way?
    Specs:
    Asus P5B Deluxe
    Intel C2D E6400
    BFG Tech. 7950gt
    Corsair 2gb DDR2-667
    Antec Sonata II w/ the included PSU
    200gb Seagate hdd
    DVD burner/writer
    分かりますか。 carl33p's Avatar
    Feb 2006
    Gville, FL
    7,170
    9
    Welcome to TechIMO.
    Read the some of the posts and links i left in this thread:
    Installing my new parts?
    For installing the motherboard, and other components i didnt include, just google them.
    Search "Installing Motherboard" / "installing Hard drive" / etc
    If you run into any problems along the way, just post here and you'll be sure to get responses back very quickly.
    Nice choices on the hardware!
    Also, to save you troubleshooting time, you may want to do this:
    Place the motherboard on a non-conductive surface(cardboard works fine)
    Hook up only the:
    GPU(gfx card)
    CPU and HSF
    RAM(only 1 stick is necessary)
    and plug in the 20pin and 4pin into the motherboard.
    Hook up your moniter, and short the 2 power-pins on the motherboard. If it boots up, you know all those MAIN components work and arent defective, and should have smooth sailing from there on out.
    (Shorting the power pins: Take a flat head screw driver and touch them on the 2 pins on the motherboard where the power button goes) It wont damage anything if you touch the wrong pins. But once it boots up, take the screw driver off. Its not good to leave it there for more than a 2-3 seconds.
    Jan 2007
    15
    Thanks ^_^
    Caveat Emptor Rootstonian's Avatar
    Mar 2005
    Out of my mind
    3,326
    Aha,,,nice case
    Let me know if you get both the hard drive and power LED to work together; I couldn't on mine.
    Nothing really too difficult in there. Get rid of that stupid air duct; mine runs around 40c at idle without it.
    Oh, and don't panic about missing drive rails; they're actually attached to the back of the plastic faceplate!
    Jan 2007
    15
    Perrty case . I'm receiving the case today so I'll be able to install the motherboard and ram. I haven't received the processor and video card so i have to keep waiting on those -_-. Also, are the blue lights from the front of the case included?
    Feb 2006
    Gville, FL
    7,170
    9
    Quote Originally Posted by Game22 View Post
    Yep.
    Should be a great experience for you. Besides connecting those little pins to the motherboard, its not too bad.
    Also, the motherboard manual will HELP you greatly. Refer to it through-out the entire process.
    Ultimate Member mrniceguy's Avatar
    Sep 2006
    Ransomtucky NY
    2,960
    why didn't you go with 800mhz ram?
    Jan 2007
    15
    Quote Originally Posted by mrniceguy View Post
    Eh, didn't really think I'll see a humongous difference. Anyways, the side panel was a bit hard to put back on, but I think I got the hang of it.
    Feb 2006
    Gville, FL
    7,170
    9
    You wouldnt have seen much a difference at all: 667 vs 800.
    If the side panel is biggest problem u run into, your in great shape.
    Mar 2005
    Out of my mind
    3,326
    I haven't had any problems with the side panel. This really a nice case; slick black paint job that shows fingerprints if you just look at it! LOL
    Reviews of case had a lot of people not liking the LED's on the front. I think they're pretty cool
    Senior Member vicarious george's Avatar
    Nov 2002
    MA
    617
    Quote Originally Posted by Rootstonian View Post
    Aha,,,nice case
    Those speakers must create a nice stereo effect.
    Intel E6600 w/ ASUS P5N-e SLI (OC: not yet)
    EVGA 8800GTS 320MB (OC: not yet)
    2GB Crucial Ballistix PC2-8000 (2x1GB)
    Mar 2005
    Out of my mind
    3,326
    Yeah, yeah, yeah...they were temporary usb powered el cheapos till I got my Christmas present. Didnt feel like running the wires around
    Now I have nice tower satellite speakers and sub woofer Thank you Santa!
    GA
    5,413
    Sonata? Did someone say Sonata?
    Great case, and it's amazing how much you can stuff into it! LOL Yeah, I know it's a mess but it gets the job done.
    Feb 2006
    Gville, FL
    7,170
    9
    OMG JLK, that thing is packed!
    I bet installing ram would take an hour... Have to move about 20 things to get to it.
  15. #15
    Mar 2005
    Out of my mind
    3,326
    That is friggn' awesome! You have Borgisized your Sonata II case
    I bow with respect to your greatness! ROFL.
    Resistance is futile
  16. #16
    Member Namie's Avatar
    Aug 2003
    379
    Did you try inserting the LED connection on the motherboard the opposite direction? Mine wouldn't turn on either but after I inserted it the opposite direction, it turned on. I have the first Sonata case, though.
  17. #17
    Mar 2005
    Out of my mind
    3,326
    Yeah, both ways... the hard drive LED works ,but the power LED flahses on and off like a mofo
  18. #18
    Jan 2007
    15
    I just received my video card today. Just the processor which hopefully comes tomorrow and I'm ready to install everything .
    This past weekend I screwed the motherboard to the case. I cut my index finger probably when trying to screw the phillip head screws in the top left corner or bottom left. :X Those 2 were a pain.
  19. #19
    Jan 2007
    15
    Update: I just finished installing windows xp and other junk =). Seems like everything is fine. CPU as it says is at ~36-37C and the gpu is at ~45C.
  20. #20
    GA
    5,413
    Congrats Game22!
    Those look like some nice idle temps too.
  1. To build or what to build lol
    By Southern Belle in forum Motherboards
    Last Post: September 5th, 2007, 04:23 AM
  2. new xp build
    By icecold7212 in forum Technical Support
    Last Post: March 13th, 2006, 02:52 AM
  3. New Build
    By Fagin in forum Technical Support
    Last Post: March 11th, 2006, 08:19 AM
  4. My first build
    By him61 in forum General Tech Discussion
    Last Post: September 28th, 2005, 11:39 PM
  5. to build or not to build, that is the question...
    By cyphen in forum General Tech Discussion
    Last Post: April 5th, 2004, 01:53 AM
