Whoa is me (need new build advice)  | |
January 15th, 2007, 12:40 AM
It arrived on friday and I felt as giddy as a kid on christmas moring. My brand new Geforce 8800 GTS. Oh...happy..day. I now know a new level of frustration. As I pulled off the side of my gateway case to pop this monster card in...horror washed over my face. It would not fit. Shame on me for buying a name brand pc when I know how to build one. I suppose I deserved this. Seems like the btx case/mobo doesn't agree with the size of the card. So there is only one thing to do in a situation like this. I have to build a gaming pc around this $400 video card.
Now I have a nice 21" widescreen monitor, gaming keyboard (logitech g15), and a nice mouse. But the last pc I built was about 4 years ago with my trusty AMD xp 2500+ barton. So I need some help on figuring out what kind of case, mobo,psu,ram,etc... to buy so that I can compliment this 8800GTS properly. I've pretty much decided I want to go with an E6400 core 2 duo processor. Looks like the right bang for the buck. I guess the mobo and PSU are probably the biggest concern. I have about $800 to spend on all the components, but if I can come away cheaper, I'd be very happy. I also don't know much about raid arrays, raid controllers, or ide controllers, so any help there would be most appreciated. |
January 15th, 2007, 12:54 AM
__________________ Powered by area 51 Alien technology
January 15th, 2007, 01:58 AM
Wyldinstinct: I would try going to a local computer store in your area and see if they can make you somthing that you can upgrade later for the price range you have, im sure they will be able help you out
Nipples...That is all
January 15th, 2007, 02:28 AM
| | 分かりますか。
Alex288288: He knows how to build a PC, and would save a considerable amount doing it himself.
You can reuse your CD-rom, and HD if you want.
You have to get DDR2 memory. DDR2 800 would be optimal but DDR2 667 would be just fine.
2GB would help with the newest games, but if the budget doesnt allow you can just add a GB later.
A 120$ mobo will do just fine. http://www.newegg.com/Product/Produc...82E16813128018 http://www.newegg.com/Product/Produc...82E16813131030 http://www.newegg.com/Product/Produc...82E16813128017
You want to get a PSU by a quality company: FSP Group, Silverstone, Enermax, OCZ, SeaSonic, etc.
A 500W would proly be sufficient, but more power never hurts. I'll let some others make the suggestions.
Case doesnt make too much a difference. Almost any ATX Mid-Tower would do.
Raid is for multiple HD's, unnessasary for you.
If you buy a new HD, get a SATA 3.0
DVD-Burners run for 30$. Go OEM, Retail isnt needed.
Your also going to need to re-install an Operating System. |
January 15th, 2007, 03:06 AM
| | Training for Bankai
| Quote:
Originally Posted by alex288288 Wyldinstinct: I would try going to a local computer store in your area and see if they can make you somthing that you can upgrade later for the price range you have, im sure they will be able help you out | Its obvious YOU work at a "local computer store"
I think you may be at the wrong site here...
Other options... GeIL Ultra 2GB DDR2 800 (PC2 6400) $220 Case 1 $35 Case 2 $30 shipped
PSU...
All the specs say between 26 and 30 Amps are needed on the +12V rail...
And while I am LOATHE to suggest an Antec over an FSP, at this level the Antec is a better choice... Antec NeoHE 430W $80
January 15th, 2007, 03:17 AM
JP....I really dont give a sht what you have to say..
And I was just suggesting that he goes to a local place near him..make it a little easier for him..soo how bout you go back into your basement and harrass some one who actually gives a sht
January 15th, 2007, 12:25 PM
Ok, so here's where I'm at so far. $200 over budget, but that's just a day of OT at work I guess. Thanks alot for the help guys. Anyone see anything I'm missing?
Qty. Product Description Unit Price Savings Total Price
Update Rosewill R5604-TBK 0.8mm SECC Screw-less Dual 120mm Fans ATX Mid Tower Computer Case - Retail
Model #: R5604
Item #: N82E16811147033
Return Policy: Standard Return Policy
In Stock
$54.99 -$5.00 Instant $49.99
Update COOLMAX Ultra ATA-133 IDE 12" Round Cable Transparent Copper Model CM-ATA133 COPPER 12" - Retail
Model #: CM-ATA133 COPPER 12"
Item #: N82E16812104634
In Stock
$4.49 $4.49
Update Intel BLKD975XBX2KR LGA 775 Intel 975X ATX Intel Motherboard - OEM
Model #: BLKD975XBX2KR
Item #: N82E16813121060
In Stock
$219.99 $219.99
Update HIPER HPU-4B580-MS ATX12V v2.2 580W Power Supply - Retail
Model #: HPU-4B580-MS
Item #: N82E16817128001
In Stock
$99.99 -$10.00 Instant $89.99
Update Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor Model BX80557E6400 - Retail
Model #: BX80557E6400
Item #: N82E16819115004
Return Policy: Processors (CPUs) Return Policy
In Stock
$221.00 $221.00
Update mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model 996527 - Retail
Model #: 996527
Item #: N82E16820146118
Out Of Stock
ETA: 1/23/2007 10:41:00 AM
Auto-Notify
$235.99 $235.99
Update Seagate Barracuda 7200.9 ST3250824A 250GB 7200 RPM IDE Ultra ATA100 Hard Drive - OEM
Model #: ST3250824A
Item #: N82E16822148100
In Stock
$78.99 $78.99
Update SONY 16X DVD±R DVD Burner With 5X DVD-RAM Write Black IDE Model DRU120C - Retail
Model #: DRU120C
Item #: N82E16827131039
In Stock
$44.99 $44.99
Update Microsoft Windows XP Home Sp2b 1pk w/Upgrade Coupon for Vista - OEM
Model #: N09-02142
Item #: N82E16832116169
Return Policy: Software Return Policy
In Stock
$89.99 $89.99
Subtotal: $1,035.42
Select All - Select None |
