Thread: lcd tv
February 1st, 2007, 08:05 AM #1Member
- Nov 2006
- 37
lcd tv
i bought an lcd tv to replace my lcd monitor. mainly so i can hook up my xbox or ps2 but also to have a bigger pc monitor.... the problem is it runs 800x600 resolution. everything looks good at 800x600 but when i change the resolution to 1024x768 everything gets blury and it gets even worse at 1280x1024. is there anything i can do to change that? i tried to adjust my video card settings and the tv settings and nothing works. i hooked it up through the vga port. the tv i bought is a Polaroid 20"..... did i buy a bad tv or is there any thing i can do to fix it?
February 1st, 2007, 11:38 AM #2
Most of the time LCD's have a "set" resolution that they work with. I say "set" because although they may work with other resolutions, most will never look as good as their default res. AFAIK, most of the newer LCD's have a default res of 1024x768. Although you have one that's considered smaller these days in the tv realm that's probably why it has a 800x600 default res.
Gi | Yuu | Jin | Rei | Makoto | Meiyo | Chuugi
February 1st, 2007, 12:03 PM #3Member
- Nov 2006
- 37
is there anything i can do or a different way of connecting it that will give me a better picture at higher resolutions? or am i going to have to live with it the way it is?
February 1st, 2007, 12:29 PM #4Junior Member
- Jan 2007
- 20
To increase the resolution of an xbox or ps2 is to simply buy the upgrade cables at best buy otherwise it will never work well.
February 1st, 2007, 12:31 PM #5Member
- Nov 2006
- 37
February 1st, 2007, 12:33 PM #6Junior Member
- Jan 2007
- 20
But Lcd tvs have one slight problem they can burn the image of a videogame onto the screen permantly and the burn out a lot fatser than an HD.
February 1st, 2007, 12:51 PM #7Member
- Nov 2006
- 37
how are either of those last 2 posts of yours helping to answer my question? im not buying a different tv.... i just want to know if there is any way for me to make the piccture look better at higher resolutions. if you cant answer that question the dont submit a post.... your just leading people who might be able to answer it to look at your posts and not my questions
February 1st, 2007, 02:21 PM #8
tell us the model of your lcd tv
February 1st, 2007, 05:32 PM #9Member
- Nov 2006
- 37
its a polaroid 20" FLM-2017
February 1st, 2007, 06:30 PM #10
Your tv should only be run in 800x600 mode as that is the actual resolution of the tv, aka there are 800 pixels across and 600 down (as shown on page 26 of your manual). If you wanted a tv to use with the computer you would have been much better off with a HDTV in 720p (1366x768) or 1080p (1920x1080). Any attempt to run a higher resolution is an attempt to have single pixels displaying more than one thing (which is impossible of course). Most people who run a tv on their computer use it as a second moniter, maybe you should look into doing that so you can have reasonable resolution for computer applications and a larger screen for computer & console gaming. sorry for the bad news btw
February 1st, 2007, 07:03 PM #11
February 1st, 2007, 07:10 PM #12
yes, buying an actual LCD TV is not best for use with a high resolution computer as default resolution for TV programs is usually 800x600 or less, usually 640x480. HD is different, but SD is about that. The best route to go would be to return the one you have, if possible, and get something like one of these:
http://www.newegg.com/Product/Produc...Subcategory=20
That would be my suggestion, or just run it at 800x600
Good luck
My Rig:
Intel Core 2 Duo E6600 @ 3.16||6GB OCZ Rev2 DDR2 800 @ 1:1 ratio
MSI 975X Platinum||GTX 275 896MB ||WD Black 640GB and 2x80GB RAID 0
Widescreen LCD monitor or Standard LCD monitor
By sweeper2 in forum Graphics Cards and DisplaysReplies: 14Last Post: December 24th, 2006, 05:01 AM -
Looking at a 26" LCD TV to replace my 19" LCD
By pinipig523 in forum Graphics Cards and DisplaysReplies: 20Last Post: March 8th, 2005, 01:24 PM -
Anyone have got this LCD?
By washe in forum Graphics Cards and DisplaysReplies: 5Last Post: October 22nd, 2004, 01:06 AM -
LCD or Plasma? Also reccomendations for a 27'' LCD/Plasma ?
By Overclocked412 in forum General Tech DiscussionReplies: 13Last Post: August 21st, 2004, 01:40 PM -
LCD TV!
By The_Saint in forum General Tech DiscussionReplies: 6Last Post: April 5th, 2004, 12:17 AM
My whole spec is as follows: Antec DF-85 Full Tower Intel i7 2600k @ 4.5GHz Cooled by Corsair H60 Asus Mobo ( I'm not sure which one) 2 x GTX 580's 120GB SSD + 1TB Seagate ( but I think the 1tb...
SLI problem? :(
