Building a gaming PC
Currently Active Users: 2362
Discussions: 200,942, Posts: 2,379,280, Members: 246,304
Old March 18th, 2007, 10:25 AM   Digg it!   #1 (permalink)
Hi. I would love to know what components some of you guys are using these days. I am about to build a new rig. Here is what I have so far and I hoping you can recommend great hardware to go with it. I want a very powerful system and cost is not really a factor. I mean, hey - I want to keep my expenses to under 2-3K. Here is what I have so far.
Lian Li case
BFG GTX8800
Pentium Core 2 Duo E6600
I am looking for the best MOBO, memory, heat sink, PSU, that goes with these compnents. I tend to buy asus Mobo's, but if someone has a better option, lay it on me. Thank you
pneuman76 is offline   Reply With Quote
Old March 19th, 2007, 03:22 PM     #2 (permalink)
this is a pretty nice mobo: ASUS P5W DH Deluxe SKT 775 ATX although I hear good things about the P5B series. Arctic freezer 64 pro for the heat sink. A strong enermax PSU will do nicely. Get some low latency 2 GIG RAM from corsair or whoever you prefere.
Personally I'd wait for the new DX10 cards to arrive and get vista OS but those are you're choices but you'll be future proof for a long while. The Ati R600 cards are round the corner so I'm waiting for them bad boys to get in stock. I sugest getting a mid range card for now until the big boys come in stock. Maybe a 7600GT or something.
AMD Athlon 64 X2 4200+. Asus 7600GT PCI-E. Asus A8N-SLI-Premium. 2 GIG Corsair XMS DDR RAM. 250GIG WD 2500KS. X-Power 500W PSU
gunstar is offline   Reply With Quote
Old March 19th, 2007, 07:21 PM     #3 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
Power Supply recommendation-
http://www.newegg.com/Product/Produc...82E16817104025
http://www.ubuntu.com
Old March 19th, 2007, 08:34 PM     #4 (permalink)
Hey Pneuman,
I just put together a system for about 1900 after the rebates. Unofficially scored about 11,000 3DMarks on the last test I did with the 8800 GTX at stock speeds and the processor OC'd at 2.9 GHZ.
Here is my parts list if yer interested. Everything went together without a hitch and I havent had any problems with any of the componants as of yet. Mine is a bit noisy as I went a bit overboard on fans to be on the safe side but I dont think I needed nearly as many as I put in the thing. The P180 case is by nature a pretty quiet and well build case.
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $179.98
ASUS Commando LGA 775 Intel P965 Express ATX Intel Motherboard - Retail $206.99
EVGA 768-P2-N831-AR GeForce 8800GTX 768MB GDDR3 PCI Express x16 HDCP Video Card - Retail$569.99
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail $314.00
Antec Performance One P180B Black 0.8mm cold rolled steel for durability through the majority of chassis 1.0mm cold rolled steel around the 4 x HDD area ATX Mid Tower Computer Case $124.99
CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply - Retail$169.99
CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X2048-8500C5D - Retail $368.00
ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink $47.99
ASUS 16X DVD±R DVD Burner with 12X DVD-RAM Write and LightScribe Black E-IDE/ATAPI Model DRW-1612BL-BK $28.99
CORSAIR CMXAF1 Fans - Retail $19.99
Dachipsta is offline   Reply With Quote
Old March 19th, 2007, 10:32 PM     #5 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
Corsair Power Supplies are also very good.
Kind of hard to read, Dach, but readable.
Old March 19th, 2007, 10:40 PM     #6 (permalink)
Figured as much....lol. Lemme see if I can square it away a bit....Corsair PS's have some good reveiws as well. Tom's I think went thru one and raved about it. What got me hooked was the variable amperage feature on the 3 12v rails. Each rail is rated for 20 amps for a total of 60 but if you overload one rail with say, 35 amps or so load, it will just take an extra 15 amps from an underloaded rail and adjust the supply to fit the demand on the rail you got over the 20 amps. That way you dont have to worry about calculating how much per rail and having to get all specific where you plug stuff in at. Attention to those kinds of details is what drew me in the Corsair direction.
Old March 19th, 2007, 10:46 PM     #7 (permalink)
There. Maybe that's a bit easier on the eyez.....lol
Old March 19th, 2007, 11:47 PM     #8 (permalink)
Reaper
him61's Avatar
Send a message via ICQ to him61 Send a message via AIM to him61 Send a message via MSN to him61 Send a message via Yahoo to him61 Send a message via Skype™ to him61
I personally would go with some different choices.
The hard drive is $89.99, not $179.98...
P965 is for Crossfire only (so far) and I havent seen a board yet (965) with an SLI Implementation. So if you are going NVidia, then I would suggest something more like this:
http://www.newegg.com/Product/Produc...82E16813131142
Many people swear on the new NVidia 6xx SLI chipsets, and this one comes with SLI capability, is C2Q compatible, and has a lot of options to play with.
I would grab a couple of those 8800 cards and throw them in SLI.
Same Processor (Quad cores arent low enough in price yet, but they will be)
Same Case
Good PSU, but I'd go for this one:
(Newegg is having a problem with their server ATM but the OCZ 700w Unit I was going to suggest had 18 amps on each of the 4 +12v rails, and could supply some of the most power hungry systems out there. It is $150 plus a rebate for $20 I believe)
http://www.tigerdirect.com/applicati...705&CatId=2531 I normally dont go to tigerdirect, but this seems to be a great deal to me. Remember, neweggs servers are down ATM, so I cant go on there.
Everything else is good.
Total: ~$2400
Now you need a monitor, an OS, Speakers, and other accesories, and that should be it. I'll modify my post later tommorow to include everything else and a more accurate final price.
him61 is offline   Reply With Quote
Old March 19th, 2007, 11:53 PM     #9 (permalink)
My bad on the drives. I bought two of them and that was taken from my cart so thats why it showed the price so high. Good catch......
building a gaming PC mbandela000 General Gaming Discussion 19 February 14th, 2005 12:11 PM
Building A GAming RIg njolakoski General Gaming Discussion 9 June 4th, 2004 01:45 AM
Building a new gaming PC StayingOccupied General Discussion and Buyer Guidance 18 February 25th, 2004 10:16 AM
Building New Gaming Comp KngtFallen_05 Motherboards 15 April 20th, 2003 06:32 AM
need help with building a gaming system girlstellmelies General Tech Discussion 11 September 6th, 2002 06:53 AM
Is It Just Me? (2916)
Wireless Televisions. (9)
Regular Build (6)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
