Results 1 to 5 of 5
    Mar 2006
    UAE
    148
    My web cam is not clear
    I have a philips web cam it was fine earlier but now the pic quality is very less and blared any body to help me out there?
    DemhaTec
    Mobile Member ShuckyD's Avatar
    Apr 2005
    S. Central PA
    3,646
    is there a focus ring on it at all? ... if so use it.. if not make sure it hasnt changed its capture size from something larger to a lower quality image
    Mobile: Thinkpad T61 | WinXP Pro | C2D T8300 CPU | 3GB DDR2 | 320GB Hybrid SSD HDD | AGN & WWAN
    Desktop: Dell XPS 8300 | 3.4 Ghz Intel i7 | 8GB DDR3 | 1TB OS, 1.5TB Mirrored DATA
    Mar 2006
    UAE
    148
    Quote Originally Posted by ShuckyD View Post
    Il check
    DemhaTec
    icer-zerocool Dj-Icer's Avatar
    May 2003
    Arakwaku, Tokyo!
    3,205
    Webcams is cheap nowadays
    Philips should be an okay product. Yeah, I would advice you to check the focus. Else, if you have another computer, try have it plug on a different computer. See which causes the problem.
    Ultimate Member Jeordiewhite's Avatar
    Feb 2002
    midvale, utah
    2,315
    Phillips suggests:
    Q: I'm getting an unsharp picture, how can I make it sharp?
    A: Turn the lens ring until you get a sharp picture.
    Just like what has been mentioned or try going into the properties of the webcam in the software your using to view it and try adjusting some of the settings for better quality too. If that doesn't work, you can find updated firmware/drivers for the web cam on their site.
    http://www.consumer.philips.com/webcams/
    Just go there and locate your camera, then on it's product page you will find it under product support.
    (´¸.·*´¯`*»- ->Jeordiewhite
  1. FTP? web cam
    By carl33p in forum Networking and Internet
    Last Post: June 10th, 2008, 09:21 AM
  2. web cam help
    By shauny36 in forum General Tech Discussion
    Last Post: January 24th, 2005, 02:25 PM
  3. web cam help
    By blu in forum Technical Support
    Last Post: October 3rd, 2004, 02:35 PM
  4. Web Cam???
    By nodnerb2 in forum General Tech Discussion
    Last Post: May 4th, 2004, 07:33 AM
  5. web cam
    By freakster in forum General Tech Discussion
    Last Post: February 6th, 2004, 12:49 PM
