Results 1 to 8 of 8
    Senior Member presence06's Avatar
    Oct 2003
    h-town
    547
    Memory mix/match
    When I built my system there was a bundle with the processor on Newegg.com.
    It came with "DUAL CHANNEL XMS " ram.
    Well, I'm looking to upgrade to 2 gigs instead of 1... and looking in EVEREST it doesn't say anything about dual channel and the model number doesn't match with what EVEREST says.
    anyways, if what i have now isn't actually dual channel, and I get dual channel memory and use it with my existing mem..will there be any conflicts?
    DFI ULTRA INFINITY NF4 >>MOBO
    Ultimate Member Jarhed7276's Avatar
    Apr 2003
    Texas
    2,230
    The memory itself dosen't itself make it dual channel. To make it dual channel you need to put the ram in the proper slots. I'm thinking this might be why Everest doesn't show it as dual channel for you because it shows as dual channel on mine.
    Edit: I looked in your manual and to make dual channel work the ram needs to be in slot 1 and 3 where slot 1 is closest to the cpu and slot 4 is furtherest away from the cpu.
    "Retreat, hell! We just got here."
    - Capt Lloyd Williams at the Battle of Belleau Wood
    Ultimate Member elroy's Avatar
    Indiana
    3,774
    When my system boots it says "dual channel" on the upper part of the boot screen when I have 2 similar sticks of ram installed.
    Benjamin Franklin
    Oct 2003
    h-town
    547
    ok, I got another question for you guys.
    I currently have Corsair XMS PC3200 1 gig in my system.
    Like i said before I'm looking to upgrade my memory.
    are there any suggestions for ram, as in :: get the same memory i have, or if there is a better option.
    Reaper him61's Avatar
    Jul 2005
    4,904
    2
    Getting the same sticks would be ideal. If not, try to match speeds and timings.
    Ultimate Member usslindstrom's Avatar
    Sep 2003
    From my house
    1,265
    In any case, if you don't get "matching" memory sticks, then the FSB will sync itself to the lowest common denominator and you'll be at the timings of your slower stick. SO, with that in mind, if you're gonna' throw the worlds greatest memory in the machine, you might just be wasting money.
    Him's right. (hehe saying that kinda' makes it sound like I don't understand English ) But yeah, try to match the stick of memory you already have with an identical twin.
    And thus it was spoken by the mighty Uss. And it was so.
    Oct 2003
    h-town
    547
    CPU-Z shows that the timings are 3-3-3-8 running dual channel. anyways, do I need to get he specific timing same or will my mother board change it?
    Jul 2005
    4,904
    2
    It will just take the lowest of the timings (Just like the speed) if you use a different latency set.
  1. mix and match RAM.
    By New2Linux in forum Processors, Memory, and Overclocking
    Last Post: October 2nd, 2006, 06:34 PM
  2. House Mix For Download - DJ Miko March House Mix
    By djm1k0 in forum IMO Community
    Last Post: March 23rd, 2006, 06:21 PM
  3. Memory speed and FSB speed - best match.
    By RAR in forum Motherboards
    Last Post: October 7th, 2004, 05:25 PM
  4. IBM T-41 laptop ||| can I mix PC2100 with PC2700 memory?
    By rastorize in forum Mobile Computing
    Last Post: October 6th, 2004, 06:30 AM
  5. FSB Memory & Processory - do they need to match?
    By DEfusion in forum Processors, Memory, and Overclocking
    Last Post: August 10th, 2004, 08:16 AM
